Priting To HP Officejet 6500A Plus E710n
This is a discussion on Priting To HP Officejet 6500A Plus E710n within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Glad it's working for you....
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Like Tree1Likes
Thread: Priting To HP Officejet 6500A Plus E710n
  1. #11
    56481
    5 times
    May 2011
    185
  3. #12
    249772
    Oct 2012
    Milton Keynes
    I can't print from my iPad 2, to my HP OfficeJet 6500 E710n-z via my router (HH3)
    I can't print from my iPad 2, my HP OfficeJet 6500 E710n-z printer is wireless enabled, but it is connected to my BT Infinity Router (British Telecomm Hub 3.0 Media Gateway {HH3}) via an Ethernet cable. This disables the printers' wireless functions, so I can't connect directly via Airprint.
    So I want to print via my router. I can connect and browse with my iPad via my home hub. But when I try to add it via "add a device" to my home network I cannot be seen on my PC. I understand that I need to make my iPad visible, but can't find how to do this on it.
    I'm running Windows 7 32bit.
    Can anyone please help?
    thanks
  4. #13
    148639
    Jan 2012
    5
    I have just connected a HP 6500 E709a via ethernet to my router. I am printing via the free HP ePrint app or Print Agent Pro.
    Printing is done via the 'Open in...' Action button.
    I installed both as the HP ePrint app doesn't appear as an option with every application's 'Open in..' menu, whereas Print Agent Pro seems to be there with most.
    I probably don't need the HP version now, but it's free and doesn't take up a lot of space.
    Print Agent has a Lite version that you can install to test compatibility before purchasing the Pro version.
    Maybe either/both the apps will work with your printer and apps?
  5. #14
    148639
    Jan 2012
    5
    Also, I think you may be able to scan to your device by installing the free HP Printer Control app too.
    BigIan279 likes this.
  6. #15
    249772
    Oct 2012
    Milton Keynes
    thanks very much Peter, I've installed the HP ePrint App, and all seems good so far
  1. HP Officejet Pro 8500 A909a
    By jong in forum AirPrint
    Last Post: 01-05-2012, 02:34 PM
  2. Replies: 0
    Last Post: 08-18-2011, 10:54 PM
  3. Printing emails from Ipad to my Hp 6500a
    By TheGeneral59 in forum iPad General Discussions
    Last Post: 06-25-2011, 04:39 AM
  4. HP AIO 6500A Plus - Cannot Print
    By bustoc in forum AirPrint
    Last Post: 04-27-2011, 12:03 AM
  5. Airprint not waking up HP 6500A plus
    By Carnut in forum AirPrint
    Last Post: 03-01-2011, 11:04 AM
airprint not working on trendnet router
e710n and ipad
how do i connect my hp officejet 6500a wireless printer to my netgear n600 wireless dual band router
how to connect hp office jet 6500a plus wirelessly ipad
hp officejet 6500a plus airprint
hp6500a plus apple ipad download
ipad can't find hp printer
ipad can't find hp6500a plus printer
netgear n600 hp 6500 static ip
officejet 6500a plus hard to connect wireless with linksys router
tew-652brp bonjour
where do i find the hp printer code on my hp 6500a plus 710 e-printer
