Charger cord failures??
This is a discussion on Charger cord failures?? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Over the last 10 days it seems 2 of the 4 charger cords I had failed. Two came with the devices and two came with ...
Results 1 to 7 of 7
    172313
    5 times
    Mar 2012
    Central Ohio
    134
    Two came with the devices and two came with 3rd party wall / car charger combo units.
    It looks like the the that failed were the original Apple cords. The chargers still work but the cords themselves seemed to have failed.
    They are always plugged an unplugged using the connector and not yanking on the cord itself.
    Anyone else ran into something similar?
    iPad Addict
    252634
    347 times
    Oct 2012
    Canada
    1,400
    Yes , I wrote about it in either IPad discussions or Off Topic! It tells you what I did to fix it. You should be able to put iPad cable problems into search and it hopefully will take you there. If not touch my avatar and look at my posts because I only posted it in the last two days. GOOD luck! squib :-)
    iPad 2.
    Peace begins with a smile.
    M. Teresa
    iPad Addict
    252634
    347 times
    Oct 2012
    Canada
    1,400
    As to what I said in the previous post in this thread, don't count on the wire and electrical tape as a long term solution! Mine lasted a couple of weeks and then DIED!! No amount of twisting, turning, taping and wiring will bring it back to life. I too, like you, have had and am having better luck with non-apple cords! The retractable seems to be the best solution for me! That's MHO!
    Man plans. God laughs.
    iPad 2.
    M. Teresa
    iPad Guru
    49414
    467 times
    North Carolina
    3,128
    Quote Originally Posted by Blue92 View Post
    Hi Blue92 - sorry for your troubles w/ these 'cables' - one would think that the most reliable link between a power charger & a device would be the cable, but obviously not true for you! At the moment, I've not had any major issues w/ 'cables' but in reviewing a lot of posts on Amazon over the years, the 'cheaper' cables can be an issue; HOWEVER, you seem to be describing the better ones offered by Apple - don't have an answer for you but just wanted to acknowledge your problem and follow subsequent posts - Dave
    iPad Addict
    252634
    347 times
    Oct 2012
    Canada
    1,400
    The cheap retractable one i bought after the two APPLE cord's died is still doing GREAT! No more flickering on the screen and I can always wake up in the morning ( or if I'm still awake ) I can trust it will be charged to 100%!
    Love and Beloved.
    iPad 2.
    M. Teresa
    iPad Ninja
    219668
    369 times
    Jun 2012
    California
    1,944
    I haven't had any problems with the Apple cords or the three non-Apple thinner cords I have, but I have a Griffin 3 meter cord that worries me. It is a durable cord, but that makes it both heavy and stiff and I worry it will cause physical damage to my 30 pin connector on the iPad with continual stresses. I lay it out very carefully and support it to try and prevent this from happening.
    iPad Addict
    252634
    347 times
    Oct 2012
    Canada
    1,400
    Quote Originally Posted by zstairlessone View Post
    That is really smart of you! I found that just the regular Apple cord that came with my ipad was starting to fall out easily because I spent TOO much time using it while it was plugged in! Is there a way you could tape a popsicle stick or tongue depressor onto the back of your ipad so it is half on the ipad and half on the cord? I bet if you did that you will find out how heavy it is! Because if the tape keeps coming off you will know for sure it's pulling on the pins! It's too bad Apple didn't make a deeper port so the pins would be more protected! I know people who use 15' cords to hook up to the HDMI port and watch stuff on their TV's. One guy i know even uses the ipad in his lap while watching the TV screen as his ipad screen! I haven't asked him how he manages to do that without bending the pins. Next time i talk to him I will definitely be asking him though!
    Love and Beloved.
    iPad 2.
    M. Teresa
  1. IPad hardware failures
    By Victguja in forum Apple iPad Polls
    Last Post: 04-02-2013, 02:07 AM
  2. Extend the USB cord on charger
    By othomsen in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-07-2012, 12:24 AM
  3. Email failures
    By Andy Tymeiz in forum iPad Help
    Last Post: 04-20-2011, 04:02 PM
  4. zagmate keyboard cord charger
    By goncrazy31 in forum New Member Introductions - Site Assistance
    Last Post: 04-07-2011, 10:08 PM
  5. Power Cord for iPad Charger?
    By jmkiska in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 12-20-2010, 09:25 PM
apple car charger failure
apple charge cord failure
apple cord forums
ipad 2 failures
ipad charger cord
ipad charger failure
ipad cord failure
ipad cords keep failing
