iPad2 charging issue
This is a discussion on iPad2 charging issue within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Dear Forum members, I have an iPad 2 since Nov. 2011. Suddenly, I have found my iPad2 is not charging from 12th March,2011. I have ...
Results 1 to 4 of 4
    177177
    Mar 2012
    Srikakulam
    Unhappy iPad2 charging issue
    Dear Forum members,
    I have an iPad 2 since Nov. 2011. Suddenly, I have found my iPad2 is not charging from 12th March,2011. I have checked the Wall charger has output of 5.2 V. The docking chord is functional since I was able to sync with my Desktop. Can anyone suggest solution.Thanks
    177117
    Mar 2012
    mars
    5
    please try with other cable to current charger head. maybe charger head got problem.
    I thinks if charging, the batt logo top right will switch to other logo. the one with the current inside.
    try install diagnostic apps for ipad. maybe u can trace if there is any wrong anywhere.
    177189
    Mar 2012
    Kansas City, MO
    6
    Charge from the computer if at all possible until you have a solid answer, wish I could help!!
    179634
    Mar 2012
    Adelaide
    13
    The iPad 2 needs a 2 Amp charger. If the original charger has failed, then you can source a cheapie 2 Amp (or higher output) USB charger from ebay. A higher Amp charger will not harm the iPad 2, as the iPad 2 will draw up to 2 Amps only. If you get a lower amp unit, then it will take a lot longer to charge the iPad.
    I've got several scattered all over the house, as well as one in the car's cigarette lighter.
  1. iPad 1 not charging issue resolved
    By johmr in forum iPad 1 Forum
    Last Post: 02-04-2012, 01:01 AM
  2. IPad2 not charging!
    By spinningking in forum iPad 2 Forum
    Last Post: 01-29-2012, 07:45 PM
  3. iPad2 - Charging in car
    By Peter_Izn in forum iPad Help
    Last Post: 10-05-2011, 10:49 AM
  4. ipad2 not charging??
    By gypsy_rhythm in forum iPad Help
    Last Post: 05-14-2011, 01:06 PM
  5. Ipad2 charging
    By Zitdoc2 in forum iPad 2 Forum
    Last Post: 04-23-2011, 12:25 AM
ipad 2 charge problem
ipad 2 charging issue
ipad 2 charging issues
ipad 2 charging problem
ipad 2 charging problems
ipad 2 not charging with wall charger
problems charging ipad 2
problems with ipad 2 charging
