HDMI not working
This is a discussion on HDMI not working within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I'm trying to connect my ipad to the TV via HDMI. There are 3 HDMI ports on my TV,. I've tried connecting the ipad to ...
Results 1 to 3 of 3
    126119
    2 times
    Nov 2011
    89
    HDMI not working
    I'm trying to connect my ipad to the TV via HDMI. There are 3 HDMI ports on my TV,. I've tried connecting the ipad to all 3 ports on th TV in turn, and changed the input on the TV to the appropriate port. None of them does anything. I am sure I have successfully done this before, and had problems getting it connected then, but succeeded eventually. Can anyone point me in the right dirction please?
    iPad Ninja
    49414
    80 times
    North Carolina
    1,924
    Hello Waterbabies - I'm assuming that you are using the Apple adapter (below left) and that you have the adapter (and power cable, as needed) attached to your iPad as shown below (right)? The black cable in the second picture is the HDMI cable going to your TV.
    For me, I would do a step-wise testing of each of these components, e.g. if you have another iPad available (your own, a friends, or a visit to an Apple store), then make sure that cable is still working; also try another HDMI cable and/or try all on a different HDMI TV. Since you tried all of your HDMI slots on the TV and selected the proper source I'm assuming that your TV is OK. I'm also assuming that your docking station on the iPad is functioning properly (any problems w/ other connections?).
    I would also suggest, if not already done that you 'Restart' and if not effective 'Reset' the iPad and try again - good luck and please post back your results - might help others!
    HDMI not working-apples-hdmi-adapter.pngHDMI not working-accessory-apple-digital-av-adapter.jpg
    174440
    2 times
    Mar 2012
    Bucks, UK
    99
    Just a thought in case it helps - what iPad do you have? If a first gen. like myself then you'd need the iPad to actually be e.g. playing a film in order to see anything on the TV as mirroring is not supported so nothing would come up if you're just on the home screen for example... or so I think anyway.
    EDIT - sorry, this post is in the iPad 2 forum, should have checked!
    iPad 1 32GB WiFi & 3G on Orange, iPhone 4 16GB on Orange, Apple TV 2nd Gen and various old iPhones and iPod's kicking around!
  1. HDMI Mirroring not working...Assistance required.
    By ammarfarook in forum iPad 2 Forum
    Last Post: 09-20-2011, 08:23 PM
  2. HBO GO and HDMI
    By AQ_OC in forum iPad Apps
    Last Post: 07-30-2011, 11:40 PM
  3. help with hdmi ?
    By gritts in forum iPad Help
    Last Post: 07-17-2011, 07:01 AM
  4. Ipad 2 JB.. Working/non working cydia apps
    By Fluidz in forum iPad Hacking
    Last Post: 07-09-2011, 05:18 PM
  5. VGA vs. HDMI
    By Bosonetta in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 04-01-2011, 03:50 PM
connect ipad to tv not working
haier ipad dock hdmi
haier ipad dock hdmi to tv issues
hdmi iphone 4 not working
iphone 4 hdmi adapter not working
iphone 4 hdmi cable not working
iphone 4 hdmi not working
iphone 4 hdmi out not working
iphone 4 hdmi output not working
iphone 4 to hdmi not working
iphone 4s hdmi cable not working
iphone 4s hdmi not working
