What is pre-jailbroken?
This is a discussion on What is pre-jailbroken? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I'm looking at buying a Ipad 2 and it is Pre-jail broken(OK),what does this mean?I have been a PC user for years and thinking about ...
Results 1 to 4 of 4
    176199
    Mar 2012
    N.D
    I'm looking at buying a Ipad 2 and it is Pre-jail broken(OK),what does this mean?I have been a PC user for years and thinking about going to the darkside.Also everything I have is set-up for PC is the Ipad going to play nicely with my network,printer etc.
    29345
    55 times
    Penarth, Wales, UK
    1,996
    Jail broken is a hacked device. Pre-jail broken means as it comes from the factory line. As it's originally sold. It's best state
    My ipad2 interacts nicely with my pc and wireless printer. Be warned, iOS is a very different way of working than ms windows. Very different.
    52417
    18 times
    May 2011
    Dorset, United Kingdom
    287
    Quote Originally Posted by sjleworthy
    As true as this is and I don't want you to be put under the impression that they're at all alike but what I'm saying, because they're not; iOS is pretty simplistic when it comes down to it. There are features that you might not understand but chances are you won't need them. In the end, providing you read the manual that comes with your iPad (can also be found very easily on the iBooks app and the apple website) you will be fine (I'm very familiar with iOS and I still read it just in case), plus, we're more than happy to help you get you over any hurdles you might get stuck on .
    On the point of your question about the iPad interacting nicely with your wifi and printer I can almost 100% garuntee that your iPad will be okay with your wifi. Something I can't be quite so sure about if whether you can print from your iPad. The iPad can only print from AirPrint enabled printers which means If you don't have one, you'll need to find some workaround (such as emailing it to your computer and printing that way). Unfortunatly AirPrint isn't always reliable, it only works on my iPad about 30% of the time, however, I'm fortunate to own a printer with an eprint functionality which means that I can email anything I need to a unique email that came with my printer (it can be changed to something memorable) and thus I get around it that way.
    Best of luck with buying your iPad and I hope I've helped.
    EDIT: Just thought I'd give you the link to an exhaustive list of AirPrint compatible printers: http://support.apple.com/kb/ht4356
    Sent via iPF from my iPad.
    14571
    632 times
    Sep 2010
    Troon, Scotland
    7,104
    Pre-Jailbroken probably means that the owner has already jailbroken the device. It will operate just like a normal iPad, but the restrictions which Apple puts around the standard iPad are lifted somewhat. This means you can add apps and tweaks to the iPad which Apple do not allow in the app store. For example, themes, tethering, fonts, and many changes to the way the "springboard" works (that's the screens you use to navigate your apps on the iPad).
    Have a look here - Ultimate List of Jailbreak Tweaks
    and here - A 2UINique iPad Theme - Winterboard
    and here - AnyAttach - Attach Any File to E-Mail (While In Mail App)
    for some examples of what you can do when jailbroken...
    My only word of caution with this is that a pre-jailbroken device will already be set-up by the owner. It may have some (or potentially lots) of stuff on it which you don't necessarily want. It may also be linked to his/her iTunes account. Normally, you want to restore a second hand device and wipe it clean. But, if you do that, you will lose the jailbreak, and if it is an iPad2 on 5.0.1 you won't be able to get the jailbreak back any time soon. It's worth checking with the seller whether it is a clean device freshly jailbroken on 5.0.1 or whether they have used it for a while and simply uninstalled their stuff from it...
    Hope that helps.
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b2 (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
  1. Jailbroken.....
    By joke90 in forum iPad General Discussions
    Last Post: 03-09-2012, 07:59 AM
  2. How do i tell if its jailbroken?
    By Chalkyianwhite3 in forum iPad Hacking
    Last Post: 07-21-2011, 08:00 AM
  3. iOS 5 or jailbroken 4.3.3?
    By Gubi in forum iPad Hacking
    Last Post: 06-10-2011, 08:39 PM
  4. Replies: 26
    Last Post: 08-09-2010, 09:35 AM
  5. Replies: 1
    Last Post: 06-26-2010, 11:29 PM
in buying used ipaf what does jailbroken mean
what does it mean to have a jail broken ipad
what does jailbroken ipad mean
what does pre-jailbroken mean
what is a jailbroken ipad 2 mean
what is a jailbroken ipad mean
what is a pre jailbroken ipad
whats mean jailbroken ipad
