Unable to purchase apps problem
This is a discussion on Unable to purchase apps problem within the iPad 2 Forum forums, part of the Apple iPad Discussions category; So this has been going on for over a month and it is annoying if I try to download an app it tell me unable ...
Results 1 to 5 of 5
    145653
    25 times
    Jan 2012
    341
    So this has been going on for over a month and it is annoying if I try to download an app it tell me unable to purchase and then it give me a app name and says 7 others could not be purchased and then the apps show up and they say waiting next to them and then I install another app and they go away...is their a fix for this?
    Attached Thumbnails Attached Thumbnails Unable to purchase apps problem-image-760626597.jpg   Unable to purchase apps problem-image-4184302580.jpg
    175291
    Mar 2012
    Kansas
    I have a similar problem I attempt to purchase an applcation and get a dialog box stating can't connect to the Itunes store. This occures 2 out of three attempts. I'm now accepting the fact my android phone is more powerful that the IPAD.
    48665
    479 times
    Brisbane, Australia
    19,173
    I would try the usual fixes for when an app or your iPad play up. First close the app completely, in this case the App store app. From the home screen do the four finger swipe up or double press the home button to reveal your multi task bar. These are all the apps that you have opened at one time. Long press the app until it jiggles and a red minus sign will appear above it. Press the minus sign, this will close the app, not delete it, now press the home button to return to your screen. It's also a good idea to close all these apps, as it helps the iPad run smoothly. See if it's working now, if not a restart is in order.
    Press and hold the power off button, the one at the top right. You will see a slide appear to power off, slide this and the screen will go dark and a Whirly will appear. When the Whirly disappears your iPad is now off. Press the power button again until the Apple logo appears, this will take a few seconds and your iPad will restart. You should restart your iPad occasionally also as it will keep it running well. Now see if it is operating. If not, then onto a reset
    Hold the power off button and the home button simultaneously, keep holding them in and you will see the power off slide appear and disappear, wait until you see the Apple logo appear before releasing the buttons. It will take a little longer for your iPad to start.
    Try it now and see how you go and let us know.
    iPad 2 64gb 3G
    145653
    25 times
    Jan 2012
    341
    Quote Originally Posted by leelai
    Thanks but I've done all those things before and just now tried it again but the problem is still their,I've seen other people with this to but so far I haven't seen anybody be able to fix it thanks though
    48665
    479 times
    Brisbane, Australia
    19,173
    Quote Originally Posted by cellur111
    Have a look at this thread, a post by Philly Joe in particular. I sure hope this is the problem.
    Apps stuck in "Waiting" mode
    iPad 2 64gb 3G
  1. DarkHaz3 HD unable to purchase
    By spiderjohn in forum iPad Hacking
    Last Post: 01-21-2012, 04:37 PM
  2. Unable to purchase app
    By GenerationX in forum iPad Help
    Last Post: 07-02-2011, 06:00 PM
  3. Can't update apps nor purchase new apps
    By supermarshbm in forum iPad General Discussions
    Last Post: 05-15-2011, 02:24 PM
  4. Unable to download apps or update apps
    By Snowdropbooks in forum iPad Apps
    Last Post: 05-15-2011, 02:42 AM
  5. unable to purchase
    By CharlesR in forum iPad Help
    Last Post: 11-07-2010, 12:05 PM
can't purchase apps on ipad
cannot buy apps from app store
cannot purchase in ipad app
cant purchase new apps for ipad2
ipad cannot purchase
unable to download application
unable to purchase
unable to purchase app store
unable to purchase apps
unable to purchase apps on ipad
unable to purchase from app store
unable to see ipad dialog box
