When I try to use there is no sound. There is no problem when they aren't connected. Used them months ago and they worked ??? I can't seem to find any info. on how to adjust it. Thanks. Joyce. iPad 2
This is a discussion on Ear buds within the iPad 2 Forum forums, part of the Apple iPad Discussions category; When I try to use there is no sound. There is no problem when they aren't connected. Used them months ago and they worked ??? ...
Make sure the volume is turned up. The earphone volume is independent of the speaker volume. Even if you are playing through the speaker at max volume, the earphone volume can be muted, and you won't know until you plug them in.
Presently using: Apple iPhone 4 | Apple iPad 2 | Apple MacBookPro | AppleTV | Apple AirPort Extreme
Where do I find the adj for earphone vol
Same place as the speakerOriginally Posted by Joyceski38
. It auto-switches to controlling the earbuds instead when they're plugged in.
Thanks finally got it to work . Joyce
Another happy customer. Thanks for the feedback, Joyce. It's really useful to know whether suggestions work.
