This may be a daft question but if I use Dropbox for documents, is it possible to access the documents while offline?
Not as a live entity it isn't. Only when you're online will drop box be synced and updated.
but if you mark documents as favourites, they are downloaded for offline use..., which is I think what you are after...
iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
Ok, Thanks. But will I still be able to view and change things in documents, even if I' m not online? Presumably they would sync next time I go online?
Oops! the last 2 messages crossed!
Yes, that is one of the very best things about DropBox. Work offline, save stuff to your DropBox folders, and everything is synced perfectly once you are back online. I consult in areas that usually do not have Wifi so this feature of DropBox is the main reason I love it.
