Can you delete old magazine issues you have purchased like we can delete apps so I dont have a bunch of issues I have already read hogging up space on my device? If possible how?
This is a discussion on Can I delete old magazine issues? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Can you delete old magazine issues you have purchased like we can delete apps so I dont have a bunch of issues I have already ...
Even though magazines end up on your newsstand shelf, they are still apps. To delete specific issues you need to open the app and go to whatever view shows all of your downloaded magazines. From that point on methods vary a bit.
Try tapping and holding on a magazine you no longer want. If an x appears at the top left corner, tap it to delete the magazine. Usually all the magazines will get the x, and possible jiggle (like when deleting apps). If so there will probably be a Done button to exit this mode. Alternately there may be an Edit button that will let you select and delete magazines (and possible other actions.
Good luck.
