Overdrive App Help
This is a discussion on Overdrive App Help within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I'm reading a library book on Overdrive. I want to get back to the Overdrive page. If I click the home screen then the Overdrive ...
Results 1 to 10 of 14
Like Tree1Likes
Thread: Overdrive App Help
    153155
    Jan 2012
    St. Augustine, FL
    7
    Overdrive App Help
    I'm reading a library book on Overdrive. I want to get back to the Overdrive page. If I click the home screen then the Overdrive app it brings me back to the page I am reading. How can I get back to the Overdrive app home screen?
    97693
    857 times
    Sep 2011
    Michigan. USA
    18,173
    Hi Angie...I am going to delete one of your other posts that you created for the same question listed above. Please avoid doing this since makes it difficult for members to follow the conversation and ability to help you if they can. This is also against forum rules.
    Thanks.
    153155
    Jan 2012
    St. Augustine, FL
    7
    I do apologize
    97693
    857 times
    Sep 2011
    Michigan. USA
    18,173
    No worries-now I am looking at my Overdrive app to see. It's been a while since I have rented a book, but if I remember--there should be a button to the left of the screen which you should be able to tap and return to your home page of overdrive.
    153155
    Jan 2012
    St. Augustine, FL
    7
    Thank you for the clue. If my page isn't fully open, has the black bars top and bottom the button is on the top left for me to return to the home page of Overdrive.
    Quote Originally Posted by skimonkey View Post
    173584
    Mar 2012
    I'm also having a problem with overdrive. When moving from one chapter to the next while reading it takes ages to load and the spinning wheel just keeps turning. Right now I'm in the middle or reading Paris Wife ( which I purchased) and it's just stuck there- won't go backwards or forwards. Very frustrating!
    97693
    857 times
    Sep 2011
    Michigan. USA
    18,173
    Hi Sue-sometimes the immediate fixes could remedy the problem.
    Have you tried to do the following?
    Do the first 2 steps first. Save step 3 as a last resort.
    1. Force the app to close?
    2. Try to restart your iPad?
    3. Try to do a soft reset?
    You can try this in order, if an app becomes funky.
    Force the app to quit by pushing the home button twice to bring up your multi-task bar. This will show all the apps that you have visited. By long pressing the app in question, it will begin to jiggle-press the red circle with the negative sign on the app. It will only quit the app and not delete. Than try to re-open the app and test out.
    Third is to do a soft reset by holding the power switch and home button together until you see the apple logo. Hope that helps!
    97693
    857 times
    Sep 2011
    Michigan. USA
    18,173
    Quote Originally Posted by angie95 View Post
    Glad you were able to get it working!
    250648
    Oct 2012
    North Dakota
    Right up front, I'll apologize. I can't seem to find the New Topic button, so I'll post my problem here.
    I installed the latest Overdrive update on my IOS 6 IPad 2. No matter what I do, I cannot get rid of the What's New screen . It pops up every time I go to my bookshelf. I press the DONE button every time but it doesn't seem to believe me. I've tried closing the app, rebooting, and more.
    Any suggestions would be appreciated.
    13576
    1444 times
    Aug 2010
    Western NY state (USA)
    11,049
    Overdrive App Help
    Quote Originally Posted by Irenejd View Post
    It's not you - this stoopid pop-up appears every time I open Overdrive on my iPhone or iPad (both running iOS 5.1.1). So, the developers have a bug in their software (cause I can't believe they would deliberately leave that pop-up there to annoy Every. Time. You. Open. The. App). I have done as you - to include scrolling through to the end of the notice in hopes that would work...
    However, all I can suggest is contacting the developer and asking them to fix it. Hopefully, they will.
  1. Understanding the Overdrive App
    By Grinchy in forum iPad Help
    Last Post: 12-07-2012, 08:34 PM
  2. Overdrive App question
    By Agent1191 in forum iPad Apps
    Last Post: 06-27-2011, 09:47 PM
  3. Overdrive Media
    By linmarie in forum iPad 2 Forum
    Last Post: 04-27-2011, 06:10 PM
  4. Overdrive for library
    By Diane B in forum iPad General Discussions
    Last Post: 04-18-2011, 01:23 PM
overdrive app is stuck in indexing
overdrive app stuck loading
overdrive ipad loading title
overdrive is stuck on
overdrive problems on ipad
overdrive stuck loading
overdrive stuck loading title
problems with overdrive on ipad
