I need help please
This is a discussion on I need help please within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I have recently installed an airport express, in my house i have 2 iphones, 2 ipads 2 pcs and an Imac, they are all working ...
Results 1 to 9 of 9
    171042
    Mar 2012
    United Kingdom
    6
    Unhappy I need help please
    I have recently installed an airport express, in my house i have 2 iphones, 2 ipads 2 pcs and an Imac, they are all working correctly on wifi with the exception of 1 ipad, which for some reason has an IP address starting 169, it works in other wifi areas but not on my home network, i have tried resetting it, resetting the network on the ipad, but it still comes back with 169, i have no idea what to try next
    PLEASE HELP
    Jason
    171042
    Mar 2012
    United Kingdom
    6
    121 views and no replies, am i doing something wrong or is it such an unusual problem that no one has any suggestions
    152243
    Jan 2012
    Busan, South Korea
    71
    I'm going to ask a really obvious question here. Have you tried to "Forget The Network" and/or "Renew Lease?" If your one iPad, that is not connecting, is holding an IP address that is distinctly different than your other devices, then it is not connecting to your home wireless. Refreshing and getting a new IP should solve the problem.
    152243
    Jan 2012
    Busan, South Korea
    71
    ...oh yes, you might also try manually setting up an static IP. Make sure all of the other entries match your other devices - same router IP, subnet, DNS, etc., but then set a static IP that is only different in the last set of numbers. For example, my home wireless has a subnet mask of 255.255.255.0, a router IP 192.168.1.1, DNS of 168.etc, etc. Just make sure the IP Address does not duplicate any other device on your home network.
    171042
    Mar 2012
    United Kingdom
    6
    Thanks for the reply, yes i have tried forgetting and renewing, i'll try a static IP when i get home, i brought my IPAD to work today and it works fine!
    138414
    Dec 2011
    United States
    86
    May also want to check your equipment . I have an older router and it will not give out more than a few ips. When I start running 4 wireless devices, things start to not being able to connect. I'm upgrading my router this weekend. See if your able to get additional wireless devices onto your network (besides the iPad). That will take this snafu out of the equation.
    Greygoose
    171042
    Mar 2012
    United Kingdom
    6
    Thanks Goose appreciate it
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    what you are describing is what happens when a device is not given an IP from the DHCP server, in your case it would be the router.
    Make sure its connecting to your network and not someone else's
    make sure your router is giving out IP's via DHCP and that its set to give out enough IP's for all of your devices.
    make sure your iPad is set to use DHCP.
    171042
    Mar 2012
    United Kingdom
    6
    Thanks Mike
169 ip
ipad 2 gets 169 ip address
ipad 2 ip 169
