Help with issh
This is a discussion on Help with issh within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi guys, I was wondering if someone would be kind enough to help me learn how to use issh. I want to ssh into my ...
Results 1 to 6 of 6
Thread: Help with issh
    18454
    15 times
    Oct 2010
    959
    Help with issh
    Hi guys,
    I was wondering if someone would be kind enough to help me learn how to use issh. I want to ssh into my laptop from home or away but not sure how to set it up. I know the ip of the laptop but when I set it up it doesnt work, is there any ports I need to open? Any settings I have to change on windows 7 to allow ssh? I want to be able to for instance to open up iTunes just using the command line. I'm quite tech savy so sort of know what I'm doing (studying computer forensics at Uni) so it must be something I'm not doing right! Any assistance would be greatly appreciated!
    32GB WIFI/3G 'The New ipad'
    7668
    2 times
    Jun 2010
    Boca Raton
    24
    Quote Originally Posted by addiosamigo View Post
    Hi guys,
    Are you specifically trying to use the SSH protocol or just remote access your Win7 laptop?
    The reason I ask is that Windows does not natively come with any SSH support at all. SSH tends to be a remote access method more specific to Unix/Linux systems. In order to access a Windows box via SSH, you'll have to install your own SSH server (e.g., cygwin+openssh or some other package), then do the usual things like configure your firewall/router to forward your incoming SSH connection (TCP port 22 by default) from your external IP to your laptop.
    On the other hand, if you're just looking for a way to remote access your Windows laptop, I'd suggest one of the RDC/RDP solutions instead since this capability is available natively in most later versions of Windows. There are dozens of RDC client apps out there for iOS. (And confusingly, the iSSH app itself will do raw RDP, but at point the SSH capabilities of the app aren't involved in any way). The same comments for firewall/router configuration as above apply, except that RDC tends to use port TCP 3389.
    As a final suggestion, if you're looking for a really simple way to remote access your system without having to configure router port forwarding (and possibly a way to track a dynamically changing external IP), you might look at one of the solutions such as LogMeIn, TeamViewer, etc. These types of remote control apps work by having both your host system and your iPad rendezvous via an external server, eliminating (in most cases) the need to do any special firewall configuration or port forwarding since both sides are creating outbound connections.
    Hope this helps.
    18454
    15 times
    Oct 2010
    959
    Hi thanks for your suggestions, I already have logmein, splashtop, etc for RDP and VNC, I was specifically looking to get SSH working. I have downloaded and installed openSSH but can't see how to create a paswrd file, there's a paswrd.exe but it doesn't seem to do anything, that's what i'm currently stuck on. If there is a client that is easier to use then I'm welcome to suggestions.
    13576
    1445 times
    Aug 2010
    Western NY state (USA)
    11,053
    AFAIK, OpenSSH on the jail broken iPad is just to get into the iPad - it's not for trying to get into another device, such as a computer.
    Just wanted to save you time in trying to go that route - all the rest of the stuff you are talking about is pretty much w-a-y over my head...
    18454
    15 times
    Oct 2010
    959
    Quote Originally Posted by Mickey330
    There's a version for windows that's also called openSSH but thanks for the heads up!
    iPad Addict
    167823
    187 times
    Feb 2012
    New York
    1,136
    VMWare for the iPad works pretty smoothly for me.
    http://vmware.com/ipad
    iPhone 4S White 16 GB iOS 7.1 ||iPad Mini 16GB (WiFi) iOS 7.0.4 Evasi0n7||AppleTV2 iOS 5.2 Seas0nPass
    Please read and abide by the forum rules
    iPhone Forums Moderator
  1. Replies: 0
    Last Post: 04-17-2011, 02:27 PM
  2. How to change root password with issh?
    By olivertimm in forum iPad Hacking
    Last Post: 08-15-2010, 07:33 AM
how to use issh
how to use issh on ipad
ipad issh help
ipad ssh tunnel
issh help
issh ipad
issh ipad help
using issh ipad
