Importing PDF drawings as books?
This is a discussion on Importing PDF drawings as books? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi, I think I'm on the right track here, but it's not working so perhaps someone here can help me out. I have a series ...
Results 1 to 7 of 7
    142898
    Dec 2011
    Fort Wayne, In
    28
    I have a series of construction drawings for an airplane I need to study. I have them assembled into a PDF which measures about 36 mb in size and had intended to import them as a book onto my iPad so I could study them as needed and they would be in order as opposed to searching all over for images.
    However, when I drag and drop the assembled pdf onto My iPad in iTunes, it hangs up indefinitely. I've waited about ten minutes for it to finish, but it never does. I do get the title, but it's grayed out.
    Any suggestions as to what I'm doing wrong or maybe a better way of doing it?
    Kevin
    94993
    Sep 2011
    6
    Hi,
    I have had no trouble with PDF,s in Books or IFiles.
    However if the drawings are in dwg ie Autocad format you may find AutocadWS better. It lets you use layers etc. I have it works well but is a bit slow.
    Ian
    161002
    Feb 2012
    Nevada
    99
    try moving just 1-page of your drawings over and see if that works.
    142898
    Dec 2011
    Fort Wayne, In
    28
    Yeah, I did that. I wonder if the size is an issue. Most ebooks seem to be a megabyte or less, while this is 36. Also, although I don't think it matters if it's in a pdf, the resolution on these is HUGE. We're talking around 12,000 pixels by 10,000...
    145622
    3 times
    Jan 2012
    South Africa
    103
    I might be asking the obvious, but are you importing the file to IBooks on the iPad?
    I have a PDF book of over 100MB in IBooks.
    The steps that I follow are below.
    1. Connect iPad to Itunes
    2. Select Books on "Ipad" in Itunes
    3. Select from File Drop down menu "add File to Library"
    4. Select file
    5. Synch iPad.
    Hope this helps
    Sent from iPad 32Gb 4G/Wi-Fi via IPF
    41072
    7 times
    83
    I use Amazon's "Send to Kindle" service. You can either email it to a Kindle address, or if you have a PC, install the software and then just right-click on any document or PDF and choose "Send to Kindle" and it shows up in my Kindle Library. Could not be simpler.
    Amazon.com Help: Kindle Personal Documents Service
    The great thing is then you can read them on any device that supports Kindle and you're not tied to an i-Device like you are with iBooks.
    142898
    Dec 2011
    Fort Wayne, In
    28
    I'll give that a shot, but my real goal here is not necessarily to get them imported AS a pdf. If there's another way, I am more than willing to listen. These are not Autocad. They're vintage scans from an antique aircraft and are in jped form, but I can convert them...
  1. Post drawings made on your ipad
    By iCan in forum iPad 2 Forum
    Last Post: 09-30-2012, 12:39 PM
  2. Replies: 16
    Last Post: 05-29-2012, 09:49 PM
  3. Drawings in iPad with the interaction of users
    By jolsna in forum iPad General Discussions
    Last Post: 02-14-2012, 10:50 PM
  4. Scetchbook drawings aka Finger drawing!
    By TylerLambert120 in forum iPad Wallpapers
    Last Post: 08-25-2011, 12:04 AM
  5. IPAD and importing Sony DRM epub books
    By os4185 in forum iPad General Discussions
    Last Post: 11-17-2010, 08:14 AM
construction drawings on ipad
drawing book pdf
drawings books in pdf
drawings books pdf
drawings of books
how to import pdfs into ipad
how to measure pdf drawings
import pdf books ipad
import pdf into ipad2
importing pdf to ipad
importing pdf to ipad 2
pdf drawings on ipad
