ipad2 camera not working!
This is a discussion on ipad2 camera not working! within the iPad 2 Forum forums, part of the Apple iPad Discussions category; would anyone know how to fix this issue, please?...
Results 1 to 6 of 6
    91289
    Aug 2011
    157355
    Jan 2012
    93
    Salut,
    Can you be more specific please. What happens when you open the Camera App?
    iPad Guru
    49414
    467 times
    North Carolina
    3,128
    Hello Michel and welcome to the forum!
    The specifics of your problem as suggested would be helpful, but you may want to try the following usual 'first' steps when an app is misbehaving:
    First, open the multi-taskbar (double tap the home buttom or use multi-finger gesturing) - find the camera app, press and hold until the app jiggles, then press the minus sign which will close the app; return to the home screen and try again.
    Second, if the above does not cure the issue, then 'Restart' and if not effective 'Reset' the iPad - directions HERE.
    If none of these suggestions work, then please post back for further advice - good luck!
    91289
    Aug 2011
    thanks. what happens is the following: the shutter usually does not open or when it does, it sometimes works for a few seconds and closes again. as it s a problem a friend of mine has, i will ask her to try your tip and let you know the result. the reset didn t work.
    91289
    Aug 2011
    no way! went to service centre and they agreed to replace it. thanks for coop
    iPad Guru
    49414
    467 times
    North Carolina
    3,128
    Quote Originally Posted by micheldubai
    Congrats! That would have been my next suggestion with the hope of a replacement!
  1. Camera not working!
    By tomster in forum iPad 2 Forum
    Last Post: 05-03-2013, 06:26 AM
  2. FaceTime camera not working
    By linsipad in forum iPad 2 Forum
    Last Post: 04-16-2013, 05:05 AM
  3. Ipad2 front camera not working
    By Piergio13 in forum iPad 2 Forum
    Last Post: 12-28-2011, 06:10 PM
  4. Camera not working!!!!
    By fbbdab in forum iPad 2 Forum
    Last Post: 08-08-2011, 03:35 PM
  5. Camera still not working
    By Ronfromcocoa in forum iPad Help
    Last Post: 07-09-2011, 09:39 PM
camera on ipad 2 not working
how to fix camera on ipad 2
how to fix front camera on ipad 2
how to fix ipad 2 camera
ipad 2 camera not working
ipad 2 camera not working fix
ipad 2 camera problems
