Ipad 2 32 GB WIFI battery
This is a discussion on Ipad 2 32 GB WIFI battery within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Ella all. I have had my beloved iPad2 wifi 32GB since last August and it has always had a good battery life and I ran ...
Results 1 to 5 of 5
    86489
    3 times
    Aug 2011
    61
    Ella all. I have had my beloved iPad2 wifi 32GB since last August and it has always had a good battery life and I ran the full cycles of battery the first few times. (fully charge, fully deplete, repeat)
    I always manually close any unused apps, keep Bluetooth off and typically use my iPad for forum browsing and Internet browsing.
    In the past week or so my battery life has gone to crap. I am losing 1% of battery life every couple of minutes. I have auto lock set to two minutes and have only a few apps set for the notifications bar.
    What can I do to resolve this issue?
    76661
    4 times
    Jul 2011
    Oregon
    272
    Daniel,
    Really sounds like something amiss to me. I have had my iPad 2 since July last, and not more than a week and a half ago, I offered to check my battery drain on both the iPad and the iPhone, by leaving them unplugged overnight. The phone had 100% still indicated the next morning, and the iPad was at 98%. I have mail set to check every 15 minutes, and I don't remember turning off location services, which shouldn't have been activated overnight anyway. I did turn off WiFi on both units (I use it all the time on both, as I tether one to the other for my only Internet access.) I do know that leaving WiFi turned on on the phone drains its battery pretty quickly whether I'm tethering or not.
    Hope that info helps.
    Brian
    (sent from my iPad)
    86489
    3 times
    Aug 2011
    61
    Well I let the battery drain to depleted this morning and then charged it completely with the iPad turned OFF. I have been using it as usual for about the last 1.5 hrs and battery is still showing 100% remaining.
    I used to drain it and fully recharge about once a month, but I feel I might have let that slip the past couple of months. For now, it seems, it I back to normal, time will tell.
    iPad Wizard
    49745
    370 times
    6,598
    Apple suggests running down your battery once a month to ensure that the battery indicator stays accurate. Maybe that's a possible fix for your problem.
    110082
    34 times
    Oct 2011
    Upstate, NY
    826
    Quote Originally Posted by Kaykaykay
    Yep, I also suggest when you do charge it that you make sure to fully charge it before using it again. The types of batteries used in iPads like to be fully charged before being pressed into action.
    32GB Wifi iPad 2 / OS 6.0
  1. Battery drainage - WiFi vs 3G
    By Laban in forum iPad General Discussions
    Last Post: 05-12-2011, 09:26 PM
  2. Intermittent Wifi issues with iPad 2 and WiFi
    By MarilynLockhart in forum iPad General Discussions
    Last Post: 04-24-2011, 11:11 PM
  3. Ipad Battery
    By Romeolo888 in forum iPad General Discussions
    Last Post: 01-11-2011, 07:08 PM
  4. iPad WiFi/3G vs. iPad WiFi + Verizon MiFi/Sprint Overdrive etc?
    By MachThree in forum iPad General Discussions
    Last Post: 12-18-2010, 05:02 PM
  5. Setting up Verizon Blackberry Tour Wifi Hotspot for Ipad Wifi
    By xlr8nflorida in forum iPad General Discussions
    Last Post: 06-14-2010, 11:09 PM
how long can ipad2 riun on battery
how long does battery last on ipad 2
how long does ipad 2 battery last
how long does the ipad 2 battery last
how long does the ipad 2 battery really last
how long does the ipad2 battery
how long ipad 2 battery last
how long the battery of i pad 2 stay
how long will my ipad 2 battery last
how long will the battery last on an ipad
ipad 2 battery cycle?
ipad 2 battery draining constantly
