Ipad 2 Battery life - What do you get?
This is a discussion on Ipad 2 Battery life - What do you get? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I have basic IPad 2 16gb wifi I've done everything I can to save power except dimming the screen. Everything else except wifi disabled. Charge ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    162913
    Feb 2012
    Toronto
    7
    I've done everything I can to save power except dimming the screen. Everything else except wifi disabled. Charge done with stock equipment.
    With average web browsing, reading, and checking my news apps, I can maybe get a 3 hour session in. before I could swear I got many more hours. I've owned it doe a couple of months now..
    How much do you guys get?
    iPad Ninja
    49414
    80 times
    North Carolina
    1,930
    Hi Crush - welcome to the forum!
    This is an oft asked question and many threads already exist on the iPad's 'battery life' - a search might have been of value -
    But as you've already implied, the iPad's battery when fully charged should deliver about 8-10 hrs (of course, depending on services such as Wi-Fi, 3G, etc. that may be active) - Apple support suggests that about once a month, you allow the battery to be pretty much drained and then re-charge - give that a try after which recharge fully and see what happens? If still a problem, you might have to deal w/ an Apple store for further evaluation - good luck!
    162913
    Feb 2012
    Toronto
    7
    Hi,
    I let it drain out almost every time..
    How long does yours last if I may ask..
    97693
    502 times
    Sep 2011
    Michigan. USA
    15,340
    I can get about a good 10-12 hours being able to surf, email, read a book,or play a game. I let it drain down to 0% every month. I really don't watch any videos on my iPad. I charge my iPad every 2 days.
    iPad Ninja
    49414
    80 times
    North Carolina
    1,930
    Quote Originally Posted by Crush View Post
    Hi,
    I let it drain out almost every time.. How long does yours last if I may ask..
    Hi Crush - I probably let my battery drain a couple of times a month, but have never really tested the time - I suspect that I'm getting close to 8 hrs or so (at least at the moment - have owned the device nearly a year); note that I leave my Wi-Fi connection ON (not my Bluetooth & don't have 3G; of course there are other potential 'drains' on power).
    However, you should certainly be getting more than 3 hrs w/ a full charge; all that I can suggest at the moment is for you to 'Reset' the iPad (directions HERE), and then w/ the battery drained, give a good overnight charge - see what happens? Please respond back - good luck!
    162913
    Feb 2012
    Toronto
    7
    Yeah I've done all that.
    My screen is at max brightness and I use it straight through the time usually reading.. I watch some CNN videos but not much..
    iPad Ninja
    49414
    80 times
    North Carolina
    1,930
    Well, my screen is dimmed a little but doubt that would make much of a difference; if you've indeed done all suggested and still getting just 3 hrs on a 'full' battery charge, then that is not normal - you've own the device just a couple of months so still under warranty - not sure 'how' your purchased the iPad, but recommend that you visit a local Apple store (if possible) and have them check it out?
    BTW, I see that you are from Toronto! Wife & I go to Canada in the summer about every other year - last visit was to Quebec - this July we are planning a return to Toronto - love that city and expect an enjoyable trip! Dave
    162913
    Feb 2012
    Toronto
    7
    Hehe actually it was an open box from best buy so someone did return it..
    Why do you dim the screen for when it's already quite dim at max? Just curious..
    iPad Ninja
    49414
    80 times
    North Carolina
    1,930
    Just don't need it that bright in the lighting I use, and probably saves a 'little' battery power, likely of no importance, though.
    Believe that from you last comment, i.e. 'open box', that you should return the iPad (may have been the issue w/ the OP, i.e. 'original purchaser') - hope that all works out well - just get another one!
    157394
    Jan 2012
    6
    Screen brightness is a big battery drainer...I have mine set to about 2/3rds brightness on the slider. I'm easily getting 10-12hrs out mine-16gb wifi only model as well. Do you get alot of heat as yours is running? Could certainly be a bad cell causing the short times.
  1. My iPad's Battery Life
    By saurik in forum iPad FAQ
    Last Post: 09-13-2011, 05:48 AM
  2. Ipad 2 battery life
    By eddkahn in forum iPad 2 Forum
    Last Post: 08-01-2011, 01:49 AM
  3. Ipad 2 4.3.3 terrible battery life
    By jonathan2435 in forum iPad 2 Forum
    Last Post: 07-02-2011, 08:18 AM
  4. The Battery Life of iPad
    By akintomide in forum iPad General Discussions
    Last Post: 04-29-2011, 05:57 PM
  5. iPad battery life.
    By Electaguitar in forum iPad General Discussions
    Last Post: 12-28-2010, 01:40 PM
how long do ipad 2 batteries last
how long does a fully charged ipad 2 last
how long does an ipad 2 battery last
how long does an ipad last
how long does battery last on ipad 2
how long does ipad 2 battery last
how long does the ipad 2 battery last
how long does the ipad 2 battery really last
how long should an ipad 2 battery last
how long should ipad 2 battery last
how many years does the ipad 2 battery last
how much battery life does an ipad 2 have
