Can I tether to a droid phone?
This is a discussion on Can I tether to a droid phone? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Im new to the iPad so excuse my ignorance. I want to use my Motorola Droid as a wifi hotspot by tethering with a USB ...
Results 1 to 10 of 13
    133601
    Dec 2011
    Watertown , CT
    8
    USB cord. My phone has a micro b input so I bought a female USB to micro b cord. I then plugged the USB cord from the iPad2 into but it didn't work. When I did a little research my phone says it will tether to a windows os. Is there
    anything else I can do? Or will the iPad only tether to an iPhone?
    129720
    18 times
    Nov 2011
    474
    157394
    Jan 2012
    6
    What type of phone do you have? I'm on verizon and I've discovered I can tether my ipad2 with the motorola droid x, x2 and droid 2 phones. This is done via bluetooth, not usb. With this connection the ipad2 uses my 3g connection. So long as the signal is good I have no trouble streaming netflix, hbo go and youtube. Forgot to mention my ipad2 is a 16gb wifi only model.
    133601
    Dec 2011
    Watertown , CT
    8
    I have the original Motorola droid. I'll have to see f I can do it with the Bluetooth . Does your phone recognize the iPad as a Bluetooth device?
    151112
    6 times
    Jan 2012
    43
    Doesn't the droid have the option to turn on 'mobile hotspot' which would give you a wifi acces point from your phone to internet. I thought it was basic from android 2.3 up.
    It's better to teach a n00b how to find information than just to give him the information blindly.
    If you find this post helpfull, please press the 'Like' button.
    157394
    Jan 2012
    6
    xlkx, yes that is correct but it costs. I prefer to use my existing 3g for no addtional charge. Of course you're not getting the speeds of wifi but if I can stream video most times that's all the speed I need. Djphelan01, Yes ...I think your original droid may work. Put the phone in discover mode(bluetooth settings) and also enable the bluetooth on your ipad. They should see each other once discovered. You'll get a code on both devices to pair them...in similar fashion of any other bluetooth devices. Once paired, connect with your ipad and you should have your 3g data stream available on your ipad.
    133601
    Dec 2011
    Watertown , CT
    8
    Thanks for the help I'll try it tomorrow .
    159794
    2 times
    Feb 2012
    Des Moines, IA
    80
    Root your droid. Then you get free hotspots
    Sent from my jailbroken iPad2 using iPF
    159794
    2 times
    Feb 2012
    Des Moines, IA
    80
    Also,the method described above does work with droidx2
    133601
    Dec 2011
    Watertown , CT
    8
    Quote Originally Posted by HowBoutThemPack View Post
    Sorry for the ignorance but what does "root your droid" mean?
    I have unlimited 3G access with my phone and I'm trying to use it as a hotspot with my wifi only Ipad2.
    I got my IPad and phone to recognize each other as a device with Bluetooth but I can't get them to connect. When I tap on a different Bluetooth device on my phone it try's to connect but when I tap on the iPad icon nothing happens. Is there something I need to do to the phone or the iPad to make them connect?
  1. iPad droid tether??
    By Biohazard58 in forum iPad General Discussions
    Last Post: 04-06-2012, 06:22 AM
  2. tether iPad2 to Droid
    By jlw0211 in forum iPad 2 Forum
    Last Post: 07-20-2011, 08:32 PM
  3. Tether iPad to Droid X
    By drsadistic in forum iPad Help
    Last Post: 06-18-2011, 07:58 PM
  4. tether from droid x to ipad via usb
    By accordlayingkit in forum iPad General Discussions
    Last Post: 03-03-2011, 11:04 PM
  5. Droid tether?
    By 09nightstervb in forum iPad General Discussions
    Last Post: 06-16-2010, 05:09 PM
bluetooth tether ipad android phone
bluetooth tether ipad to android phone
cable tether ipad to android
ipad bluetooth tether to android phone
ipad usb tether android
tether droid x2 to ipad
tether ipad 2 to android phone via usb cable
tether ipad to android bluetooth
tether ipad to android phone bluetooth
usb tether android to ipad
usb tether ipad to android phone
