Remote Desktop
This is a discussion on Remote Desktop within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi, is there an iPad app that you can remote control your desktop computer running on windows different from team viewer..
Thanks....
Remote Desktop
Thanks.
02-04-2012 11:49 AM
Tried it and it works well. Thanks guys..
Originally Posted by
Redneck_Randy
Works fantastically - fully recommended.
At my age it can be difficult to understand what others regard as simple!
ziffos
Just downloaded Splashtop and like the look. Only problem I am having is controlling the position of the pointer. Seems a bit hit and miss as you can't see it under your finger, so difficult to be precise.
Also, you can't remotely access you computer when it has gone to sleep, unless I am missing something. And I don't wand to disable sleep mode when not at home.
the2ems
To move the mouse pointer you touch the ipad screen and pointer will go to that point.
You are correct to say that if your computer is asleep or off then you are unable to access it.
ziffos
So this is the first page that seemed as I'd it would be helpful. Umm.... So if my computers fairly slow will it be slow if I buy this app. Because I don't want o waste my money by having I run just as slowly on my iPad as on my pc
thedrscompanion
.??? Well, if you remote control a very slow computer, the fact the you remotely control it will for sure not make it faster! In fact it will slow down slightly (maybe not noticeable).
thedrscompanion
Your computer will not run any faster when doing this as it will still be your computer doing all the hard processing work.
- You may not post replies
- You may not edit your posts
Forum Rules
By tse in forum iPad Apps
Last Post: 06-17-2011, 01:08 PM
By Hopdevil in forum iPad Apps
Last Post: 06-09-2011, 01:36 PM
By David Vice in forum iPad FAQ
Last Post: 03-17-2011, 02:33 AM
By Premium1337 in forum iPad Apps
Last Post: 03-11-2011, 10:18 PM
By skibum in forum iPad General Discussions
Last Post: 08-25-2010, 05:04 PM
app for pc remote access
best ipad 2012 remote desktop
best ipad remote deaktop app 2012
best ipad remote desktop
best ipad remote desktop 2012
best remote desktop app 2012 ipad2
best remote desktop app for ipad 2012
best remote desktop for ipad 2012
best remote desktop for ipad 2012 ?
ipad app best remote desktop 2012
is there a remote desktop app for ipad
online desktop app ipad2 2012
remote access for ipad 2 2012
remote desktop
remote desktop for ipad discussions
remote desktop ipad
remote desktop ipad 2012
remote pc windows ipad
