Keynote problem
This is a discussion on Keynote problem within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Ll the data has gone from my presentations on iPad 2 the name and dates are still on keynotes but no slides Help urgent Chris ...
Results 1 to 3 of 3
Thread: Keynote problem
    160393
    Feb 2012
    Keynote problem
    Help urgent
    Chris china
    48665
    479 times
    Brisbane, Australia
    19,126
    Hi Chris and welcome to the Forum!
    Sit tight and someone will be along who can answer your question, in the meantime:
    iOS5 Tips and Tricks
    Please post only once on your issue as per Forum rules, your other post has now been deleted.
    iPad 2 64gb 3G
    577 times
    Dayton, WA
    13,177
    First, try the usual fixes listed at the bottom of the post (if you haven't already).
    If those don't work, try this.
    If you are using iCloud with Keynote, go to icloud.com on your computer and check to see if the file is there. Download a copy you computer as a backup, just in case.
    Back on the iPad, turn off iCloud in Keynote, delete the document, then turn it back on again and wait for the document to sync again. If it does not, go back to iCloud and if the document is gone, upload it again from the computer.
    Hopefully the iCloud copy was good and you're back in business. If it has the same problem the file was probably corrupt on both the iPad and iCloud.
    In that case the only thing you can do is try to restore the iPad from your last backup, and hope the file was still good then. Be aware that a restore from backup turns back the clock for the entire iPad; so make copies of everything you've done since that backup. Better yet, always make off iPad copies of anything you consider important.
    I don't consider iCloud.com a good backup, because syncing is automatic you can't be sure that changes or document deletions won't propagate to it before you can correct mistakes. A free Box.com account can be used to upload iWorks files via the WebDAV option. I consider it a great second copy location, though your files must be less than 100MB for the free account.
    Good luck.
  1. Keynote
    By tecknoes in forum iPad 2 Forum
    Last Post: 11-14-2011, 09:53 AM
  2. Problem advancing slide in Keynote
    By tangoguy in forum iWork Forum
    Last Post: 09-27-2011, 10:49 AM
  3. Keynote App
    By sdlep in forum iPad Apps
    Last Post: 02-19-2011, 11:08 PM
  4. Keynote
    By brhon in forum iPad Apps
    Last Post: 05-17-2010, 12:16 AM
how to recover a keynote presentation on ipad
how to restore keynote from icloud
how to restore keynote project on ipad
icloud won't sync keynote presentation
keynote presentation won't download
keynote presentation won't open on ipad
keynote presentation wont open
keynote prsentation wont open on ipad
my keynote presentations disappeared
my keynote won't open on my ipad.
my keynote wont open on ipad
recover keynote on ipad
