No wifi connection
This is a discussion on No wifi connection within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I have an ipad2 with wifi. I can usually connect into my friends' wifi, using their key codes. One friend has a laptop and iPad ...
Results 1 to 4 of 4
    127385
    Nov 2011
    England
    Question No wifi connection
    I have an ipad2 with wifi. I can usually connect into my friends' wifi, using their key codes. One friend has a laptop and iPad connected with a Talktalk wifi system.
    I can pick up his signal but it will not allow me to access it and doesn't request a key code to allow me access. He is a silver surfer, as am I, and he doesn't know why. Is it something he did when he set his wifi system up?
    160273
    Feb 2012
    45
    It sounds like your friend's wifi security is the problem. It may have been set to allow only certain, specified devices to connect. If you can ask your friend to go to his router settings page and check to see if an access control list is enabled. If so, you can ask him to add your iPad to the list of allowed devices. For that, you'll need to find your MAC code from your iPad settings/general/about "Wi-Fi Address". It'll be something like EG:47:94:F6:7H:88
    89227
    7 times
    Aug 2011
    UK
    295
    Depends how savvy the person who set up his router was tbh.
    Whoever might have used MAC filtering where only known MAC addresses for each device are allowed go connect, but it would be rare for normal users to do this.
    At the cost of wiping existing WiFi keys you could try to reset network connections on your iPad.
    No other data will be lost as long as you select the right option that is lol!
    89227
    7 times
    Aug 2011
    UK
    295
    'Snap' Darren
  1. Replies: 50
    Last Post: 10-12-2012, 10:42 PM
  2. IOS 5 Last WiFi Connection Not Used
    By MikeV99 in forum iPad OS
    Last Post: 10-14-2011, 01:33 PM
  3. Replies: 3
    Last Post: 06-04-2011, 08:16 AM
  4. Always use 3G, even with Wifi connection
    By DontUnderstandMyIpad in forum iPad General Discussions
    Last Post: 01-23-2011, 12:15 AM
  5. Replies: 3
ipad 2 no wifi
ipad 2 no wifi connection
ipad 2 no wifi signal
ipad 2 not finding wifi
ipad no wi-fi
ipad no wifi
ipad no wifi connection
no wifi connection on ipad 2
no wifi ipad 2
no wifi on ipad
no wifi on ipad 2
no wifi signal on ipad 2
