May I ask if anyone one knows why when I past in the job description box in a resume app the words appear for a second and disappear. Please help.
This is a discussion on Copy and paste within the iPad 2 Forum forums, part of the Apple iPad Discussions category; May I ask if anyone one knows why when I past in the job description box in a resume app the words appear for a ...
Hi and welcome to the Forum!
If it works just for a second, sounds to me that the app may be playing up, give these steps a try.
From the home screen do the four finger swipe up or double press the home button to reveal your multi task bar. These are all the apps that you have opened at one time. Long press the app until it jiggles and a red minus sign will appear above it. Press the minus sign, this will close the app, not delete it, now press the home button to return to your screen. It's also a good idea to close all these apps, as it helps the iPad run smoothly. Let us know how you go, if this doesn't work could you tell us the name of the app your using
iOS5 Tips and Tricks
iPad 2 64gb 3G
Hi Epdmdc - welcome to the forum!
If the previous post does not solve your issue, please clarify what you are trying to do? I'm a little confused, e.g. what app are you even using for the above description? Please respond w/ more specific information and maybe others can respond - good luck!![]()
