Going on vacation Friday can I charge my little iPod (square one) using iPad ? Can I use my iPod with iPad as speakers
This is a discussion on Ipad2 and ipod info within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Going on vacation Friday can I charge my little iPod (square one) using iPad ? Can I use my iPod with iPad as speakers...
I do not think you can use the iPad to be a power source for another device or use it as external speakers for another unit.
Perhaps others may have other options. Regarding the speakers, why not purchase an inexpensive portable speaker device that you can use with your iPod? Regarding charger, why not just bring your iPod charger...unless you do not have it anymore? Once again, a universal charger for your iPod may also be an option for you.
You should be able to charge the iPod using the iPad charger (if that is what you meant), though if it's an older iPod be sure to use it's charging cord. Some of the earlier classic models used different pins to charge. If it is so old it uses a firewire port, then use the iPod's charger, not the iPads. At any rate, you can try it at home. I shouldn't hurt anything.
You might be able to trick the iPad into being a speaker with a combination of cords to convert the iPod's output to a mono-micorphone input and some recording style app. I don't recommend it. You can get a cheap portable speaker that will sound better for less money. Not to say it will sound very good, but neither does the iPad's speaker.
