Is this the best way to sort this out?
This is a discussion on Is this the best way to sort this out? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi Guys, As an older type of person who is not really a computer expert I could use a little advice here. Probably the best ...
Results 1 to 10 of 10
    78465
    3 times
    Jul 2011
    Blackburn in NW of . . . . . . . . . . . . England
    110
    Hi Guys,
    As an older type of person who is not really a computer expert I could use a little advice here. Probably the best way to explain this is for me to tell you what I THINK may work and then for you to tell me why it won't. lol
    OK, I have an old netbook with a lot of Microsoft Office Word files that I would like to copy/paste across to my iPad 2 so that I can read, edit and add to them. All 3 of those actions are very important.
    I plan to make a copy of all the files and save it to the desktop of the Netbook. This will be the copy that I work with and the original will be kept safe just in case it all goes pear shaped. I will then convert the copy to .epub.
    It should then be possible to upload the files to iTunes and then a quick sync with the iPad and Bob's your Aunt Fanny.
    Will that do the trick or is there a simpler way?
    Cheers,
    Steve.
    I have an iPad 2 32gb wi-fi but just learning how to use it.
    37823
    748 times
    Cranbrook, Kent, UK
    17,132
    It's a lot simpler than that, get the DropBox app on your netbook and iPad (it's a free download) then drag your MS Word files into it on your netbook and hey presto, they will appear in your DropBox on your iPad. You then need a suitable office app, something like Quickoffice (I like to use this) and you can open the files in this app and edit as much as you like.
    29345
    55 times
    Penarth, Wales, UK
    1,996
    Yup. Or even just email them to yourself. IPad will sort them and open them in, like Gab says, any appropriate office app (I use Office2HD). This app has an incredibly simple drag and drop wifi file transfer system too - hey Prestatyn, simples! Robert's your father's bro and all that.
    78465
    3 times
    Jul 2011
    110
    Thanks for the advice, guys.
    I haven't discarded the idea of using e-mails but I just fancy using the Drop-box idea first, mostly because I already have it, installed but unused, on the iPad.
    A couple of points though. You said ...... "You then need a suitable office app," ..... OK, what does an app need to make it suitable?
    I'm not a cheapo but I don't like buying apps that don't work so is there a suitable free app with maybe a paid for upgrade that I can buy if the freebie works out?
    Cheers,
    Steve
    37823
    748 times
    Cranbrook, Kent, UK
    17,132
    I'm not aware of a free office app but other may know better.
    29345
    55 times
    Penarth, Wales, UK
    1,996
    Suitable apps? ALL paid office apps. Best spend a few quid if I were you. A tenner or so will do it, and don't worry, it WILL work. The few available free office stylee apps aren't worth the grief, and as mentioned, they're few and far between, if any even.
    157355
    Jan 2012
    93
    Quote Originally Posted by Gabriel1
    You might recommend CloudOn. Requires Dropbox account - both free for the moment. Cheers, Mike.
    37823
    748 times
    Cranbrook, Kent, UK
    17,132
    Quote Originally Posted by mlaurencg4
    Thanks Mike.....CloudOn isn't available natively in the UK although there are workarounds......as the OP asked for simple I avoided anything that needed a workaround.....but good call.
    Banned
    142294
    4 times
    Dec 2011
    china
    201
    wow, thanks for sharing. and if you want to see some apple accessories, you can go and check this.
    Wholesale Electronics - China Electronics Store - Drop Ship from China
    78465
    3 times
    Jul 2011
    110
    Quick update .....
    Hi again,
    Just thought that I should let you know what I eventually did to get it to work.
    I had a look at various Office Apps including QuickOffice and Office2hd and QuickOffice seemed to be taking a pounding in the review section so I opted for Office2hd. I ain't saying that any other office app wouldn't work, just that as a first time buyer, this one looked easier to use in the reviews and "Easier to use" is what us oldies like to see (some of us, anyway, lol)
    Anyway, it does what I want it to do so that's me sorted. Thanks for all the help and advice.
    Cheers,
    Steve
  1. Photo sort
    By bibititta in forum iPad Help
    Last Post: 01-08-2012, 06:27 AM
  2. Sort of new
    By Lynn3956 in forum New Member Introductions - Site Assistance
    Last Post: 12-15-2011, 03:40 PM
  3. New-sort of!
    By Allired2 in forum New Member Introductions - Site Assistance
    Last Post: 08-27-2011, 10:01 PM
  4. How to sort my contact by last name ?
    By paulyeo11 in forum iPad General Discussions
    Last Post: 07-16-2011, 02:43 PM
  5. Numbers - can it sort?
    By djb in forum iWork Forum
    Last Post: 06-29-2011, 02:48 PM
best way to sort ipad apps
best way to sort out email
