Possible to have note sync between ipad2 and iphone ? How?
This is a discussion on Possible to have note sync between ipad2 and iphone ? How? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hello, I have an iPhone 3GS and ipad2 How can I have old note in the iPhone and note in the ipad2 sync ? In ...
Results 1 to 5 of 5
    153190
    Jan 2012
    29
    Hello,
    In the iPhone note I have on top account and I can choose between all notes, iPhone and iCloud
    How come I don't have this possible choices in the ipad2 note?
    Where is it? Can I select on ipad2 what note to see? All, iPad or iCloud?
    Thanks for helping
    577 times
    Dayton, WA
    13,181
    When you first set up note syncing on the iPad or iPhone, if you already have notes you would have been offered a chance to sync all the notes, or keep your local notes. It sounds like you kept them on the iPhone, and did not on the iPad.
    The result is that you have local notes on the iPhone and also your iCloud synced notes. On the iPad all you have is the iCloud stuff. You won't see the Account button and note sections if you only have one account.
    If you don't have a huge number of local notes on the iPhone, just copy&paste them to new notes in the iCloud section, and then delete the old note. They will soon show up on the iPad. Once all notes are copied, the local notes section is empty, and you are sure they are synced with iCloud (check the iPad to be sure), you can go into the iCloud settings and turn off Note syncing. Choose to delete them on the iPhone. Then turn them back on. The notes should sync back to the iPhone, and the local account will be gone.
    At least that was the way it worked the one time I did this myself.
    153190
    Jan 2012
    29
    thankssss a lot, it was just like you said and I fix it as you said, one more question, I have some notes in office word and excell documents that I want to transfer to the NOTE of idevice how can I easily do it? if copy and paste, how do I copy from word or excell ?
    577 times
    Dayton, WA
    13,181
    I can't think of any quick and easy way to do this. It will all come down to copy and paste.
    I see two basic approaches. You can copy the documents to the iPad, then use a viewing or editing app to copy and paste to Notes, or you can copy what you want to an email on the compouter, mail it to yourself, then copy and paste to Notes from the Mail app.
    Another option, the one I'd probably use (do use actually), is to get an Evernote account. With the Evernote app on the iPad, iPhone, and computer you can make your new notes on the computer and let them sync to the iPad. If you still want them in Notes for some reason you can copy and paste between Evernote and Notes. If you want to move your Notes notes to the Evernote you use the special Evernote email address (provided with the account) to mail them from Notes.
    The only real downside to Evernote is that with the free account attachments, and sometimes notes that you haven't accessed in a while are stored on the sever; so you need and internet connection to get to them. And you've got a maximum note limitation. I've rarely found this to be a problem; but I don't make hundreds of notes a month and, and with my iPhone's hotspot I can almost always get on the internet if I want.
    No reason you can't use both, of course. I do, though I mostly use notes as a kind of editable clipboard for text.
    13576
    743 times
    Aug 2010
    Western NY state (USA)
    9,270
    You could also take a look at the app iFiles ($1.99, USD). You can transfer, basically, any file type between iDevices with it, as long as they are on the same WiFi network. It's a universal app, and one purchase will allow you to put it on both the iPhone and the iPad. Which is a good thing, as the app has to be open on both devices for the transfer to work. But, it works well.
    I've used it to send pictures, text files, Word doc, etc., between my iPhone and iPad while I sit all comfortable and lazy in the recliner.
    But, yeah, Evernote is pretty good, too.
  1. why no folders sync from iphone to ipad2?
    By marmagi in forum iPad General Discussions
    Last Post: 01-17-2012, 02:23 PM
  2. How to sync calendar on iphone with ipad2?
    By shauns in forum iPad 2 Forum
    Last Post: 10-31-2011, 09:56 PM
  3. Cant sync imessage on IPAD2 with IPhone 4Gs
    By ladyk28 in forum iPad Help
    Last Post: 10-16-2011, 03:57 PM
  4. Sync iphone cal (activesync) with ipad2
    By bigmick777 in forum iPad 2 Forum
    Last Post: 09-07-2011, 11:08 AM
  5. Free hand note taking app for iphone 4 can save note in dropbox
    By paulyeo11 in forum iPad General Discussions
    Last Post: 08-28-2011, 12:18 AM
can not synchronized notes from iphone to ipad2
get notes to sync between ipad2 and iphone4s
how to sync iphone to ipad 2
how to sync note pad betwen iphone 4 and ipad
how to sync notes between iphone and ipad
how to sync notes from ipad 2 to iphone 4
i can't get my notes to sync between my old ipad and my new ipad
ipad notes won't sync with iphone
my notes won't sync on my ipad 2 and iphone
notes won't sync to iphone
notes wont sync between iphone and ipad
notes wont sync from iphone to ipad
