Its moved an inch up my display and i cant moveit back... See screenshot
Cheers
This is a discussion on Help my keyboard has moved... within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Its moved an inch up my display and i cant moveit back... See screenshot Cheers...
Cheers
Hold the button on the bottom right, the one with the keyboard with an arrow under it, until you see 'Dock' and 'Split', then tap 'Dock'. You can also just drag it down using the same button.
