Power from USB
This is a discussion on Power from USB within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Question. When connected to my PC USB port my iPad states "not charging". My ipodtouch could recharge from the USB port. Anybody know why the ...
Results 1 to 9 of 9
Thread: Power from USB
    132094
    Dec 2011
    UK
    159
    Power from USB
    Question. When connected to my PC USB port my iPad states "not charging". My ipodtouch could recharge from the USB port. Anybody know why the difference ?
    29345
    50 times
    Penarth, Wales, UK
    1,936
    Most computers don't deliver enough energy to charge your iPad via the USB cable. Most won't even keep the charge constant, whilst some newer computers deliver enough charge to charge up your iPad very very slowly. This is a known fact and most normal.
    The best solution is to use the wall charger. Even this can vary in times depending on what and how many power hungry services or apps you have open in memory at any given time, whether the iPad is off or on even.
    iPad Ninja
    49414
    80 times
    North Carolina
    1,930
    Agree w/ the previous post - this is an oft asked question and a little searching would have provided much information -
    The iPad charger provides 10W of power (basically 5V x 2Amps); below is a partial quote from a Wiki article on USB (part of the 'power' discussion) - the numbers come no where needed to charge your iPad; a 'twickle' charge may be provided w/ the higher power USB options but you'll still see the no charging indicator; as suggested use the wall adapter or a similarly powered alternative - good luck!
    The USB 1.x and 2.0 specifications provide a 5 V supply on a single wire from which connected USB devices may draw power. The specification provides for no more than 5.25 V and no less than 4.75 V (5 V±5%) between the positive and negative bus power lines. For USB 3.0, the voltage supplied by low-powered hub ports is 4.45–5.25 V.[38]
    A unit load is defined as 100 mA in USB 2.0, and 150 mA in USB 3.0. A device may draw a maximum of 5 unit loads (500 mA) from a port in USB 2.0; 6 (900 mA) in USB 3.0. There are two types of devices: low-power and high-power. A low-power device draws at most 1 unit load, with minimum operating voltage of 4.4 V in USB 2.0, and 4 V in USB 3.0. A high-power device draws the maximum number of unit loads permitted by the standard. Every device functions initially as low-power but the device may request high-power and will get it if the power is available on the providing bus.[39]
    Some devices, such as high-speed external disk drives, require more than 500 mA of current[40] and therefore cannot be powered from one USB 2.0 port. Such devices usually come with Y-shaped cable that has two USB connectors to be plugged into a computer. With such a cable, a device can draw power from two USB ports simultaneously.[41]
    29345
    50 times
    Penarth, Wales, UK
    1,936
    Yup, a 'twickle' is all you'll get
    129720
    18 times
    Nov 2011
    474
    I bought a couple of these but have not received them yet.
    XMultiple iPad USB Charging Adapter IXP1-500
    66612
    6 times
    Jun 2011
    Montreal Canada
    110
    Hard to imagine how it can work... Let's us know.
    Sent from my iPad2 3G 32 gig (not JB'ed) / using iPF
    129720
    18 times
    Nov 2011
    474
    They are on back order so it may be awhile
    150082
    Jan 2012
    west wales
    44
    It takes my ipad over 2hrs to charge up to 100% from a wall charger, is this normal?
    iPad Ninja
    49414
    80 times
    North Carolina
    1,930
    Quote Originally Posted by robert1305 View Post
    Well that's a 'loaded' question - We need to know at what level of discharge that you plug in your wall adapter? Two hours when the iPad's battery is pretty much discharged is as expected - check this Apple Battery Support Article for more information -good luck!
  1. Will not power up
    By dakin in forum iPad Help
    Last Post: 06-14-2012, 08:54 AM
  2. Power Consumption
    By ADubin in forum iPad 2 Forum
    Last Post: 10-08-2011, 07:10 PM
  3. Pivot Power
    By Gloon in forum Off-Topic
    Last Post: 05-13-2011, 06:41 PM
  4. power connectionkit
    By ronaren in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 01-20-2011, 08:05 AM
  5. iPad won't power on at all
    By ocdetails in forum iPad Help
    Last Post: 12-08-2010, 11:15 PM
4.75 5.25 4.45 usb
4.75 5.25 4.45 usb power
low power usb stick
power from usb
usb
