Results 1 to 5 of 5
    98056
    Sep 2011
    51
    How to lighten the memory of my ipad
    Hi
    my iPad 32 GB is full (only 1 gb remai ing.) and 22 GB of apps
    I wonder if i can cancel them from my iPad and levare them on my iMac. Every time iTunes starts, it makes a backup on my pc but don't understand (my ignorance, sorry) how to leve the apps only on my pc without charging my iPad and, case by case, mobbing one or another one to my iPad
    Another question : iCloud? I should have 5 gb free but don't understand if it can be' used as a backup and how
    Thanks a lot in ad ance
    Fabio
    48854
    90 times
    Weston WI
    869
    Hold one app until it starts to jiggle and an x appears on a corner. Touch the x to delete the app. Apps can be downloaded again from iTunes. Game advances, etc. however, will be lost.
    98056
    Sep 2011
    51
    How could I avoid that every time I connect my iPad to my iMac All the apps in the iMac are downloaded again on my iPad?
    38516
    18 times
    Seattle
    555
    Connect your ipad to your computer, fire up iTunes, click on your ipad on the left hand side, once it loads your ipad info in the middle pane click on the apps tab, select the radio button towards the top that allows you to select individual apps, go down the list and uncheck the apps you don't want sync'd to your ipad and then perform a sync.
    iPad 2 64GB Wifi 5.1.1 jailbroken
    5965
    7 times
    Jun 2010
    314
    Also are you automatically syncing your iPad? To prevent this , go to preferences in iTunes and make sure that automatic syncing is turned off. This gives you time to go through all the apps listed and deselect those you do not want on your iPad. Then you can sync.
    IPad 1, iPad 2, Ipod Touch 4, Ipod Touch 2, Ipod Nano, Iphone 4S and Ipad Mini
  1. I must add memory to my ipad, where how
    By Lisirein in forum iPad Help
    Last Post: 11-30-2011, 10:44 AM
  2. Improve Your Memory With The 4 Most Powerful Memory Techniques!
    By MissBanana in forum iPad App Announcements
    Last Post: 11-28-2011, 01:17 AM
  3. Ipad Memory optimizing...
    By Chessadi in forum iPad 2 Forum
    Last Post: 10-23-2011, 10:57 AM
  4. Replies: 2
    Last Post: 08-08-2011, 11:42 AM
hiw i can ehhance memory of my ipad
ipad 2 memory full
ipad full memory
ipad memory full
ipad memory full with other
ipad memory is full
memory full on ipad
my ipad memory full
my ipad memory is full
my ipad says memory full
why does my ipad memory
why is my ipad memory full
