IPad2 not charging!
This is a discussion on IPad2 not charging! within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Using wall charger, ipad2 will not charge! brand new, less than 1 month. Not jailbroken. searched forum, could not find anything, matching my issue. thanks!...
Results 1 to 10 of 11
    156376
    Jan 2012
    los angeles
    10
    IPad2 not charging!
    56481
    5 times
    May 2011
    185
    If you're using the wall charger that came with the iPad, take it and the iPad to an Apple store or where you bought the iPad. Have them check it out.
    If you're using an earlier charger, like one that came with your iPod, it may not put out enough current to show the iPad as charging.
    If you're using an after market charger, make sure it was made for the iPad2.
    156376
    Jan 2012
    los angeles
    10
    Quote Originally Posted by drb_52 View Post
    Thank you! I am using the one that came in the box, with the IPad2...
    56481
    5 times
    May 2011
    185
    I take it that it did work when you first got it. Probably a bad charger, but it can't hurt to have both the charger and iPad in hand when you have them test it for you.
    Good luck.
    iPad Ninja
    49414
    80 times
    North Carolina
    1,930
    Quote Originally Posted by spinningking View Post
    Welcome to the forum!
    If you're using the 10W charger that came w/ your iPad, then make sure there is indeed power in the wall socket (some can be switched off) or try the charger in another wall outlet. If available exchange the USB-docking cord for a different one or check the cord w/ another device, such as an iPod.
    If none of these suggestions are helpful, then I agree that you likely need the Apple or Apple-accredited people to check the charger, cord, and iPad itself for the potential problem - good luck and post back your solution - may help others!
    156376
    Jan 2012
    los angeles
    10
    Good luck.
    Yes, It did work out of the box! Won't even work using usb plugged into a computer. Second time it has done this in a week.
    56481
    5 times
    May 2011
    185
    It probably would not work from a usb on a pc since those don't put out the current needed either. The suggestions above are also very good. It could very well be the cable. Take that with you too for testing.
    156376
    Jan 2012
    los angeles
    10
    Quote Originally Posted by giradman View Post
    Thank You for the welcome! Nothing has worked, I guess I will take it back to Best Buy, see if they can help. Thanks for all replies.
    152099
    Jan 2012
    San Diego, CA
    8
    Let us know what happens. My guess is the charging port in the iPad has somehow gone bad.
    156376
    Jan 2012
    los angeles
    10
    Quote Originally Posted by Arizona View Post
    Will do, soon as I get back! Thanks again.
  1. iPad2 - Charging in car
    By Peter_Izn in forum iPad Help
    Last Post: 10-05-2011, 10:49 AM
  2. iPad2 not charging through via PC USB
    By bat0nas in forum iPad Help
    Last Post: 06-22-2011, 04:53 AM
  3. ipad2 not charging??
    By gypsy_rhythm in forum iPad Help
    Last Post: 05-14-2011, 01:06 PM
  4. Ipad2 charging
    By Zitdoc2 in forum iPad 2 Forum
    Last Post: 04-23-2011, 12:25 AM
  5. Charging Ipad2 battery
    By AppleNut in forum iPad 2 Forum
    Last Post: 03-27-2011, 03:58 PM
ipad 2 not charging
ipad 2 not charging wall
ipad 2 not charging when plugged into wall charger
ipad 2 not charging with wall charger
ipad 2 won't charge with wall charger
ipad 2 wont charge with wall charger
ipad will not charge with wall charger
ipad won't charge with wall charger
ipad2 not charging
my ipad2 is not charging
new ipad 2 not charging
why is my ipad 2 not charging
