protective cover
This is a discussion on protective cover within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I wanted to keep the fingerprints and glare off of my screen.I bought a protective cover but I'm having no good luck with putting it ...
Results 1 to 3 of 3
    147180
    Jan 2012
    philadelphia, pa
    23
    Unhappy protective cover
    I wanted to keep the fingerprints and glare off of my screen.I bought a protective cover but I'm having no good luck with putting it on. I already used my 2 covers. I can't get away from the air bubbles no matter how smoothly I try to get the cover. Does anyone have any ideas what I can do?
    iPad Wizard
    49745
    370 times
    6,591
    Tips I've seen for applying screen protectors:
    Wipe down screen; use tape to lift any remaining lint; unroll from one side and start sticking as you peel off backing; do it in a steamy bathroom, to limit lint; smooth out bubbles with credit card. Some are applied damp, so you have a bit of liquid help for adjusting.
    Some accessory kiosks and shops will apply them for you.
    All that said, I've never found need for a screen protector, but YMMV.
    147180
    Jan 2012
    philadelphia, pa
    23
    thank you. my husband was trying for me since he has steadier hands than me. So I will tell him and we'll see how it goes.
  1. My iPad Protective Case
    By luralin in forum International iPad Users
    Last Post: 07-20-2011, 09:52 PM
  2. would protective film be overkill?
    By poisonivy in forum iPad General Discussions
    Last Post: 07-14-2011, 02:07 PM
  3. Protective screen cover
    By zelt2007 in forum iPad FAQ
    Last Post: 07-02-2011, 09:27 PM
  4. [REQ] A thin, yet protective back cover
    By Gubi in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-24-2011, 07:36 PM
  5. Most Protective Case?
    By CjChronos in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 12-04-2010, 08:41 AM
do i need a protective cover for my ipad
do i need a screen cover on my ipad
do i need protective cover on ipad?
do ipads need protective covers
do ipads need the protective cover
do you need protective cover for ipad
do you need protective covering for screen on ipad
does i padcome with protective cover
help i need a protective cover for my ipad
i cant put a protective cover on my ipad
kisosks that put protective covering on i phones
should i get a protective cover for my ipad
