Keep IPAD On In Case?
This is a discussion on Keep IPAD On In Case? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I have the ILUV portfollio case with bluetooth keyboard. Is it safe to keep the IPAD on inside the case with it closed? Wondering if ...
Results 1 to 9 of 9
    153913
    Jan 2012
    I have the ILUV portfollio case with bluetooth keyboard. Is it safe to keep the IPAD on inside the case with it closed? Wondering if the IPAD generates heat in the standby mode and could it damage the IPAD or keyboard.
    37823
    479 times
    Cranbrook, Kent, UK
    15,237
    Both my iPads reside in sleep mode in cases when I am not using them without any issues, so I think you are fine.
    11187
    Aug 2010
    NJ
    106
    Same here.....not an issue or a problem.
    iPad Wizard
    49745
    370 times
    6,597
    At one point, Apple advised charging iPad outside of a case, but I don't know if that advice is still on its website.
    I figured that if I felt my iPad getting warm while charging in its case, I'd worry about it. If not, I wouldn't. I didn't, so I don't. (I use a back-only case anyway.)
    Worse comes to worse, I figure that getting warm might diminish battery life a bit, in which case I will just get a battery replacement sooner than later.
    49720
    277 times
    SC
    5,365
    Actually, I think Apple prefers that you NEVER turn your iPad off. Steve Jobs didn't like on/off buttons. I leave mine on 24/7 and charge it will in its case. Absolutely no problems. The iPad 2 is very energy efficient and will use very little, if any, power while in sleep mode.
    iPad Wizard
    49745
    370 times
    6,597
    Quote Originally Posted by AQ_OC View Post
    I turn mine off maybe every six months or so, like if something hangs.
    111434
    317 times
    Oct 2011
    Near the Ionian Nebula, still searching for Earth
    8,375
    Agreed. My hope is the 10th generation iPad will have a surgically implanted option (powered by the body's electrical field), with ocular holographic display. Bye bye bifocals.
    iPad Wizard
    49745
    370 times
    6,597
    Quote Originally Posted by AdmiralAdama View Post
    Agreed. My hope is the 10th generation iPad will have a surgically implanted option with ocular holographic display. Bye bye bifocals.
    We're going to have to wait till iPad 10 for that?! Rats.
    iPad Wizard
    49745
    370 times
    6,597
    Apple - Batteries - iPad
    Just checked on Apple site. Lower right says to remove while charging, depending on some cases. So if yours isn't getting warm while charging, no worries.
  1. iPad case, folio case better than Smartcover
    By lomus in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 09-27-2011, 04:06 PM
  2. YooBao iPad 2 case modification - now perfect leather case for me
    By gortyargen in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-04-2011, 02:16 PM
  3. Ozaki iCoat iPad Case Grain 60' - Microfiber foldable case for iPad
    By leneo34 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 02-22-2011, 03:42 AM
  4. Case-Mate Gelli Case for iPad
    By Libby in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 12-21-2010, 10:52 PM
  5. SwitchEasy Nude case for iPad. Possibly the BEST minimalist case! PIC link inside.
    By FtrV8 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-03-2010, 08:36 PM
charging ipadin case
ipad 2 got hot while charging
ipad 2 hot while standby
ipad gets hot during charging
ipad gets hot in case
is it ok to leave my ipad in sleep mode
is it ok to leave the ipad in sleep mode
keep ipad on
leave it on ipad case
safe to keep ipad in case
should i leave my ipad in sleep mode?
will ipad gets hot in case?
