Results 1 to 9 of 9
    146453
    Jan 2012
    13
    Email not showing in the body
    When I go to check emails I get the list on the left showing all the new mail. I also get a brief portion of the message in that left column.
    The email never loads into the body section on the right, that just remains a blank page with no text.
    Is there a setting or some other function I have to do to get it to load on the right side so I can read it all?
    If I hit reply to an email, the text does appear.
    153789
    Jan 2012
    Hi there Gamalot, my email has also been doing this for the last few days, hope an answer is posted soon to solve this
    13576
    803 times
    Aug 2010
    Western NY state (USA)
    9,444
    Try this - that usually fixes a lot of "hinky" iPad behavior:
    Reset: Hold both the power and home buttons until the screen goes dark and the Apple logo then appears (the slide to unlock screen may or may not appear). Once the logo appears, release the buttons. After a time, your homescreen will appear. Please note that it may take some time for the Apple logo to appear or for your homescreen to appear (or both). This is normal. Eventually, the homescreen will appear.
    If either, or both (!) of these don't work, holler back and we'll see if we can figure out something else. Good luck.
    146453
    Jan 2012
    13
    Thank you very kindly Marilyn. I did as you instructed and all is working as it should now and emails are in the main body as they should be. Too bad I have to go back into my settings and try to figure out all the different things I changed while trying to tackle this issue on my own. All I could think is that while my wife was playing around trying to learn functions that she might have changed a setting that caused the email issue.
    153789
    Jan 2012
    Cheers too Marilyn, mine sorted aswell
    13576
    803 times
    Aug 2010
    9,444
    Great! Glad I could help. It's always nice to know that giving the iPad a good, swift kick in the ... software helps!
    Thanks for the update - from both of youse.
    154539
    Jan 2012
    Delhi
    Hi Marilyn,
    I am a new user on the forum, and joined because I was facing this problem.
    Thanks a lot, your solution worked (earlier I thought Ctrl+Alt+Del was a MS monopoly
    146453
    Jan 2012
    13
    I still have to wonder if any one has a clue as to why this happens? Apparently, I am not alone and there does seem to be a few IPad lls that get hinky but why? All I know is it was working fine one day for me and when my wife tried to check her mail it was not showing. Thanks to this forum and knowledgable people like Marilyn we got the fix but this seems eriely like the same garbage that happens regularly with my MS based PC that caused me to turn to Apple/Mac
    216492
    Jun 2012
    Montreal Canada
    Hey! I just tried your advice and I am very pleased to inform you that everything is great and back to normal.
    thank you so much for your help in solving this problem.
  1. Body of email will not load
    By TexasAngler in forum iPad Help
    Last Post: 01-13-2012, 09:14 AM
  2. Replies: 3
    Last Post: 01-02-2012, 08:59 AM
  3. Saving the body of email message
    By Parrori1 in forum iPad Help
    Last Post: 08-27-2011, 11:35 PM
  4. showing photo in e-mail body
    By ronaren in forum iPad Help
    Last Post: 05-31-2011, 04:32 PM
email messages not showing on ipad
email not showing on ipad
emails not displaying on ipad
emails not showing on ipad
ipad email body not showing
ipad email not visible
ipad email shows no text
ipad emails not showing
ipad not displaying email
ipad not displaying email content
mail on ipad, content does not load
why is ipad not showing me my messages
