My Ipad 2 is dented.. I'm confused.. Help!
This is a discussion on My Ipad 2 is dented.. I'm confused.. Help! within the iPad 2 Forum forums, part of the Apple iPad Discussions category; After coming home from work yesterday, and much to my shock I found my Ipad2 on the floor, after it must have fallen off of ...
Results 1 to 10 of 11
    153527
    Jan 2012
    After coming home from work yesterday, and much to my shock I found my Ipad2 on the floor, after it must have fallen off of my bed, somehow..someway. Everything seemed fine until I opened it up, where I then noticed that the volume control icon that pops up in the center of the screen wouldn't go away. I also noticed the most minimal of minimal dents located at exactly where you would change the volume. The volume controls are stuck, and won't move. I received this Ipad as a gift for Christmas only 3 weeks ago, and I'm not sure of what the coverage is on it in regards to getting it fixed. Does anyone know what the policy is here? Any help is greatly appreciated. Thanks.
    129720
    18 times
    Nov 2011
    474
    If you don't have accidental coverage then you will have to pay for the repair and it does sound like your ipad will need repairs. I have read other threads where people have dropped their ipad and the button was stuck and the volume pop up won't go away. That corner seems to be a weak spot on the ipad2's.
    25512
    17 times
    Dec 2010
    493
    The purchase of a new iPad comes with a one year warranty with apple. Tho I'm unsure what is actually covered. If there is an apple store in your area I'd recommend taking your iPad there and see what they can do.
    153646
    Jan 2012
    9
    Quote Originally Posted by Jobey813
    This is exactly what happened to me earlier today!!!! Please tell me after you go to the apple store!!
    iPad Wizard
    49745
    370 times
    6,598
    Quote Originally Posted by Sonicrobby View Post
    The warranty doesn't cover damage caused by the owner.
    154260
    Jan 2012
    Liverpool, UK
    This happened to me a couple of days ago, and I was going to go in store until I read ccooluke's post on here. I only have 2 posts so I can't post a link to it, but its, "dropped-ipad-switch-stuck" and its on the front page of the ipad forum.
    Totally worked for me. If you don't care that its a little dented, it will sort it out. Then, just hope you get some pixel burn out so you can get it replaced by Apple :P
    212714
    Jun 2012
    Quote Originally Posted by riotsarah View Post
    Can you share with me how this person fixed the situation?
    142432
    Dec 2011
    This happened to mine as well. As I was doing research on how to fix it, I saw someone's post saying they noticed the screen was risen a little bit in that spot. Just push that spot down and it's fixed. The volume button (up on mine) doesn't click the same. But it is still useable. Cheapest solution I've found.
    Hope this helps.
    Banned
    129445
    3 times
    Nov 2011
    United States
    255
    Those small non metal backs that clamp on to the back of iPads, are extra protection for the corners of your iPad. I bought one when I first got mine.
    221057
    Jun 2012
    USA
    Dented at Volume Control
    I have the same problem. My iPad slipped of my couch and hit the sewing machine, which had it's cover on. My iPad landed on an edge of the cover, right at the volume button. This resulted in the volume button being continuously depressed and showing the volume icon on the screen.
    I found a quick, and cheap fix.
    Binder clips.
    That is, if you're not one to really care about the aesthetics.
  1. Confused abt iPad 2 Multitasking
    By ScorpionBlues in forum iPad 2 Forum
    Last Post: 11-18-2011, 05:38 PM
  2. confused re which ipad
    By CatJ in forum New Member Introductions - Site Assistance
    Last Post: 03-04-2011, 01:42 AM
  3. Confused ipad User
    By princs in forum New Member Introductions - Site Assistance
    Last Post: 12-30-2010, 03:35 AM
  4. Dropped, dented and sleep/wake barely works.
    By Sfoanna in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 09-08-2010, 02:57 AM
dent in ipad 2
dent in ipad volume icon won't go away
how to fix dented corner on ipad
ipad 2 dented corner fix
ipad 2 volume button dented
ipad 2 volume control button stuck
ipad dents easily
ipad volume button stuck
ipad volume control stuck
ipad volume icon won't go away dent
is there any way to fix a dented ipad?
jammed volume button on ipad
