Hi I have a problem with my camera it doesn't work anymore ,is there anybody to know what should I do?
This is a discussion on Camera of ipad within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi I have a problem with my camera it doesn't work anymore ,is there anybody to know what should I do?...
Have you tried quit the app by pressing the home button twice? You can do this by hitting the home button twice to bring up your multi-task bar. This will show all the apps that you have visited. By long pressing the app in question until it jiggles and press the red circle with the negative sign. It will only quit the app and not delete. Than try to re-open the app and test out.
If that doesn't work, restart the iPad by pressing the power switch down to power off. Third is to do a reset by holding the power switch and home button together until you see the apple logo. Hope that helps!
Thanks ,but i do all of this things but not working i dont know what happened to my ipad ,actually its shutter not opening maybe it is hurt by sth or hardware problem . İ dont know!Originally Posted by skimonkey
See if this thread can help you: Camera not working!
