Backlight not working
This is a discussion on Backlight not working within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I have an iPad 2 here that has had its LCD display and digitiser replaced and now the backlight doesn't work. I've searched and searched ...
Results 1 to 4 of 4
    150706
    Jan 2012
    Sligo, Ireland
    I have an iPad 2 here that has had its LCD display and digitiser replaced and now the backlight doesn't work. I've searched and searched for a possible fix. I have reset it and also restored through itunes. I have ordered a new LCD ribbon cable to replace that incase that's the problem but it's not looking good. Any suggestions?
    163634
    Feb 2012
    Belgium
    I've got the exact same problem with my iPad, did you find a solution for this?
    148239
    2 times
    Jan 2012
    142
    Sounds like it still may be covered under the warranty. Any Apple stores nearby? If not go to the site and look for support or a phone number. If you had the display and digitizer replaced, where did you send it?
    163634
    Feb 2012
    Belgium
    I replaced it myself, therefore I don't think it will be covered under warranty.
    Meanwhile I discovered that the LCD backlight chip on the mainboard is probably broken, which is most likely caused by creating a short-circuit while disconnecting the LCD connector with my metal spudger.
    But I found a repair service that can repair my mainboard.
  1. Who has Backlight bleeding?
    By donka in forum Apple iPad Polls
    Last Post: 10-08-2011, 03:47 PM
  2. Backlight bleed
    By Mungo in forum iPad 2 Forum
    Last Post: 08-18-2011, 03:23 PM
  3. Backlight bleeding
    By OttoRijswijk in forum iPad General Discussions
    Last Post: 07-22-2011, 12:28 AM
  4. iPad backlight not working
    By gunnai in forum iPad Help
    Last Post: 05-31-2011, 06:09 PM
  5. LCD backlight bleeding?
    By Stefx in forum iPad 2 Forum
    Last Post: 03-14-2011, 06:01 PM
backlight on ipad not working
i[ad 2 lcd doenst work
ipad 2 backlight chip
ipad 2 backlight not working
ipad 2 backlight not working after digitizer replacement
ipad 2 backlight not working after screen replacement
ipad 2 lcd not working
ipad 2 no backlight after digitizer replacement
ipad 2 no backlight after screen replacement
ipad 2 no backlight repair
ipad 3 backlight not working
ipad backlight not working
Tags for this Thread
