? How to Delete Duplicate Events in Calendar?
This is a discussion on ? How to Delete Duplicate Events in Calendar? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Join Date: Sep 2005 Posts: 5 Duplicates in Calendar permalink The calendar on my iPad2 is synced via iCloud to both of my Macs. For ...
Results 1 to 10 of 15
    109012
    Oct 2011
    20
    The calendar on my iPad2 is synced via iCloud to both of my Macs. For some reason, all of the events on the iPad2 calendar are duplicated. However, that is not the case on either the calendar on iCloud or my Macs.
    Unfortunately, if I delete any of the dupes on the iPad2, that event will be completely deleted from both iCloud & my Macs (since they are all synced).
    So, how can I delete the duplicated events on the iPad2 without affecting those same events on iCloud or my Macs,
    Thank you kindly for any help.
    32660
    2 times
    Feb 2011
    155
    Check to see if you have two calendars set up. I had that problem because I sync everything thru Google calendar, but didn't turn off the onboard built-in calendar. Turned off the onboard calendar....viola no more dupes.
    577 times
    Dayton, WA
    13,181
    Try this.
    Go to Settings > iCloud and sign out of the account.
    Now go to Settings > Mail, Contacts, Calendars and see if you still have an iCloud account. If you do, delete it.
    In both cases choose to delete the contacts and calendars. This only deletes them from the iPad, not iCloud or the Mac, so your data is safe.
    Now go back to Settings > iCloud and sign back in.
    109012
    Oct 2011
    20
    Quote Originally Posted by Wokiebear
    No, I only have one calendar.
    109012
    Oct 2011
    20
    Quote Originally Posted by twerppoet
    Try this.
    Thank you for the suggestion, but I happily resolved the problem. I simply went to Settings > iCloud & turned off calendar syncing. When prompted, I chose to delete all events from the iPad calendar. When I turned syncing back on, the calendar was restored with no dupes. Thanks again.
    577 times
    Dayton, WA
    13,181
    Glad you got it fixed.
    10519
    Jul 2010
    Georgia
    108
    I also have the same problem. I deleted all calendars from the iPad and iPhone, my Outlook calendar only has two appointements in it for the entire year, but If I go to icloud.com and log in and look at calendars, I still see THREE of every event. I'm at wit's end.
    Thanks,
    577 times
    Dayton, WA
    13,181
    If at some point in the syncing cycle you duplicated those appointments for real, then the only way to get rid of them will be to manually delete the extras.
    Visit icloud.com on a computer and check out the Calendar app. If they are duplicated there, then manual deletion it is.
    10519
    Jul 2010
    Georgia
    108
    I went to icloud.com and there were dups there. I deleted the dups, but now when I sync the remaining event does not show up on either my iPhone or iPad. I'm sorry, but iCloud stinks.
    Thanks for taking time to reply.
    577 times
    Dayton, WA
    13,181
    Sign out of iCloud in Settings, and sign back in.
  1. Duplicate calendar events
    By Sammy73 in forum iPad Help
    Last Post: 11-28-2011, 08:53 PM
  2. How to delete duplicate contacts?
    By Norman in forum iPad Help
    Last Post: 01-25-2011, 02:14 AM
  3. iPAD duplicate calendar entries
    By bigd in forum iPad Help
    Last Post: 01-25-2011, 02:07 AM
  4. Multiple all day calendar events
    By afknight in forum iPad Help
    Last Post: 10-28-2010, 05:16 PM
  5. Replies: 4
    Last Post: 09-29-2010, 11:26 PM
app to remove duplicate calendar events
can't delete duplicate events in iphone
delete duplicate iphone events
duplicate calendar events on iphone & ipad
erase duplicate events on iphone
how to delete date on iphoen clanedar
how to delete duplicate appointments on iphone calendar
how to delete duplicate calendar entries on iphone
how to delete duplicate events on iphone calendar
how to eliminate dupes on ipad calendar
ipad calendar duplicates
remove duplicate calendar items iphone
