? How to Delete Duplicate Events in Calendar?
This is a discussion on ? How to Delete Duplicate Events in Calendar? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; OK, thanks to my smart daughter, I followed her suggestion and downloaded and installed the iCloud Control Panel on my PC and used that to ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    10519
    Jul 2010
    Georgia
    108
    OK, thanks to my smart daughter, I followed her suggestion and downloaded and installed the iCloud Control Panel on my PC and used that to sync and the Calendar on my iPad and iPhone are in sync with Outlook.
  3. #12
    1523 times
    Walla Walla, WA
    15,431
    Quote Originally Posted by jcherepy
    I didn't realize you were missing that part. Glad your smart daughter was around to straighten us out.
  4. #13
    129294
    Nov 2011
    iCloud pc settings error
    So, trying to set up iCloud to sync contacts and calendar on my pc (window7) and get error 0x80004005. Can't complete so relying on iTunes to sync with outlook. Creates multiple duplicates of some entries (6 plus sometimes) and not of others. Any ideas how to do any of the following? Also note, apple genius bar was unsuccessful...they sent me to the windows store....who were also unsuccessful in resolving my issue. For background, I have many items in outlook that I pulled over from an exchange server which is no longer in play. I use gmail for email. So very few ofcontacts and none of my calendar entries are in gmail.
    1) fix error mentioned above so I can sync with iCloud. The error could have to do with windows defender ( which is turned off by the way in lieu of Symantec protection). Supposed solution is to turn off system restore, reboot, then turn on again. Tried it...still receive the error at tail end of setting up iCloud sync. Ugh!
    2) set up for calendar entries to merge upon sync instead of multiple entries?
    3) delete duplicate entries in any way aside from opening each calendar entry individually to edit and delete.
    Side note...i wonder if every time I plug into iTunes to sync that it creates new entries for some items....is there a setting to fix this?
    Any help is much appreciated. I am feeling regrets for trying to switch to iPad/iPhone....it shouldn't be this hard!
    Thanks in advance!
    S
  5. #14
    258914
    Nov 2012
    Hi,
    I have duplicate calendar events on my iPad. I am not using the iCloud calendar, it has been set to off. My duplicates are from my gmail account contacts. I deleted the contacts out of gmail and those events don't show up when logged into gmail. I had the similar issue with my iPhone. I deleted my gmail account on my iPhone and then added it back. The duplicates were gone. Tried the same thing with the iPad with no luck. How do I remove these events, I can select it but have no delete option?
    Thanks for any suggestions!
  6. #15
    258914
    Nov 2012
    After messing around in the settings, my wife discovered turning off the Facebook calendar removed the duplicate entries.
  1. Duplicate calendar events
    By Sammy73 in forum iPad Help
    Last Post: 11-28-2011, 08:53 PM
  2. How to delete duplicate contacts?
    By Norman in forum iPad Help
    Last Post: 01-25-2011, 02:14 AM
  3. iPAD duplicate calendar entries
    By bigd in forum iPad Help
    Last Post: 01-25-2011, 02:07 AM
  4. Multiple all day calendar events
    By afknight in forum iPad Help
    Last Post: 10-28-2010, 05:16 PM
  5. Replies: 4
    Last Post: 09-29-2010, 11:26 PM
calendar event duplicated ipod
calendar events are duplicated on iphone
how to delelt duplicates on ipad calendar
how to delete duplicate events on calendar on ipad
how to delete multiple events in icloud
how to duplicate how to delete an event on ipad calendar
ipad calendar duplication
ipad calendar problem calendar duplicate dates
