32gb or 64gb
This is a discussion on 32gb or 64gb within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I am thinking of buying a ipad 2 but do not want to spend money if i don't need to and there is quite a ...
Results 1 to 9 of 9
Thread: 32gb or 64gb
    149030
    Jan 2012
    5
    32gb or 64gb
    I am thinking of buying a ipad 2 but do not want to spend money if i don't need to and there is quite a price difference any one any advice, also can i use my present iphone 4s apps on the ipad or do i have to rebuy them all under a new account
    29345
    50 times
    Penarth, Wales, UK
    1,936
    first off, hi there
    1) most peeps go for the 32. this seems to be a standard. this will hold a shed load of everything. a quick web search will give you more general 'specifics' on how many movies, apps, phots, songs etc etc can be stored.
    2) yes, you can use your same iphone 4 account with your ipad. you dont need to re-buy the apps, just re-download them direct to your ipad from the app store, or sync (copy) them over via itunes. But, some apps are ipad specific and wont run on the iphone. All your iphone apps will run on your ipad, but some apps have ipad specific versions in the app store - these are called 'HD' apps. these apps are optimised to fully utilise the ipad's bigger screen res. the HD versions usually cost over and above the normal price you've already paid, but are generally well worth it.
    50680
    May 2011
    UK
    127
    Quote Originally Posted by kevb59
    What do you intend to use it for? That might help people answer specifically.
    I was the same place last april. Opted for 32 to save money on 64 but now I think I could've got away with 16 - I don't use it to store much, and have Dropbox etc. linked to laptop and from there to external storage devices. I do a bit of photography and love music but I find iPad apps quality too inferior - music sounds tinny even through hi-fi. My mp3 player is preferable.
    My main use for iPad after 9 months is
    Browsing web from the comfy chair
    Keeping up with news, papers etc.
    Keeping up socially, blogs, forums, networking etc.
    Checking emails
    Streaming videos, youtube etc. and iPlayer content through the TV.
    Playing pinball games
    Hence, 16Gb would have done me fine. All heavyweight and serious work I turn to the laptop.
    62708
    Jun 2011
    77
    I have the 16Gb and it's plenty for me.
    52417
    18 times
    May 2011
    Dorset, United Kingdom
    287
    If buying from an apple store, most of them allow you to buy an iPad and then upgrade to a larger size if you need to. I believe you can only upgrade though (although I may be wrong). If this is the case you could buy the 16GB see how you find it and upgrade if needs be. A quick word of warning though, you only have x number of days to upgrade and it does vary so check with the store before you follow my advice.
    Proud owner of a 32GB wifi iPad2 iOS5.
    149030
    Jan 2012
    5
    Thanks very much for all the advice,i think i will go for the 32gb middle of the range but think that will be more than enough as my useage is nearly the same as Ian's
    41494
    13
    My rule for technology, regardless of what it is..... Always buy the best you can afford.
    149030
    Jan 2012
    5
    I wouldn't buy any thing then !!
    110082
    34 times
    Oct 2011
    Upstate, NY
    830
    Quote Originally Posted by kevb59 View Post
    Good choice. The 32GB model has that Goldilocks quality to it - Its "just right". The only people that seem to run out of space are those that insist on storing entire movies in their iPad or those that just must have their entire 4500 song music library on the thing. Otherwise, you wont get close to using all the storage.
    32GB Wifi iPad 2 / OS 6.0
  1. 16GB, 32GB, or 64GB
    By tnbug in forum iPad 2 Forum
    Last Post: 10-28-2012, 08:13 PM
  2. Which ipad 2 best for streaming live TV? 16gb? 32gb? 64gb?
    By justdrawinglines in forum iPad 2 Forum
    Last Post: 07-20-2011, 06:15 AM
  3. Do you wish you had purchased the 64gb?(32gb owners)
    By G.P in forum iPad General Discussions
    Last Post: 07-20-2010, 10:00 PM
how many hd movies can 32gb hold
how many hd movies can 64gb hold
how many movies can 32gb ipad hold
how many movies can a 32gb ipad hold
how many videos can 32gb hold
how much can 32gb ipad hold
how much can a 32gb ipad hold
how much can be stored on 32gb ipad
how much does 32gb ipad hold
how much does a 32gb ipad hold
how much will 32gb ipad hold
how much will a 32gb ipad hold
