Is there a way to view SWF presentations?
This is a discussion on Is there a way to view SWF presentations? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I'm trying to view my lectures from university on my ipad 2, but Safari doesn't seem to support them. It's not a normal animation, but ...
I'm trying to view my lectures from university on my ipad 2, but Safari doesn't seem to support them. It's not a normal animation, but rather like a ppt presentation where you click through various information points on each slide. I can only find swf converters to make them into mp4, but surely that will remove the "click-to-proceed" function? On my PC they open in Chrome without a hitch and everything is beautiful, but I believe that Chrome isn't available for the ipad 2 either. If anyone could give me a clue that would be so great
I've been searching the forum and google for ages and turned up nothing!
01-08-2012 03:06 AM
Originally Posted by
retropedro
SWF is an Adobe Flash File format; you'll need a Flash Reader.
Flash cannot and will not be supported on iPad.
I can't believe you've turned up nothing regarding iPad and flash. Every single google entry on the first page of a 'iPad and swf' search comes up with converters and flash references. Surely this tells you something?
All of the converters are to change it to video formats compatible with iOS but, like I said, the presentations contain animations and information that are directed by the facility to click your way though, like a ppt. I want to be able to keep it in a non-video format to be able to skip back and forth through slides and animations (of which there are many). As far as I can see, there is no flash reader available for iOS with full support as they look to be geared towards either animation only or games only with no overlap. There are a couple of browsers, but without full flash support, so they can't even be guaranteed to work with these files. It may be possible for me to get the presentations in the JAR format, which also operates a click function and is identical to the SWF presentations, but I can't find a JAR compatible viewer for iOS either. Safari has failed to open the files as well.
Yes, whichever way you do it you,ll not get much joy. As you say, there are several flash and associated browsers and apps available, but so far, I've yet to find any that as remotely usable or flash compatible, no matter what they claim.
You can certainly get converters that make a stand alone video, but not a non-linear or non distructive stream, with the same interaction you get in ppt and other swf presentations.
iSwifter might do it for you?
Hey, have a look at this tutorial: How to Play SWF File on iPad
- You may not post replies
- You may not edit your posts
Forum Rules
By amiliou in forum iPad Apps
Last Post: 09-20-2011, 02:03 PM
By hubbabubba in forum iPad Hacking
Last Post: 08-27-2011, 12:56 AM
By 99ccoffman in forum iPad Help
Last Post: 08-01-2011, 06:57 PM
By kevincousland in forum iPad Apps
Last Post: 06-20-2011, 06:13 AM
By alekhya in forum iPad Development
Last Post: 02-18-2011, 05:44 AM
how to open swf files on ipad
ipad swf reader
ipad swf viewer
open .swf on ipad
open swf ipad
open swf on ipad
swf on ipad
swf reader for ipad
swf reader ipad
swf viewer for ipad
view swf on ipad
watch swf on ipad
