Another GPS Question
This is a discussion on Another GPS Question within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Thanks to those that helped with my last question. What is the best piece of hardware that I can buy so that I can receive ...
Results 1 to 2 of 2
    148054
    Jan 2012
    Thanks to those that helped with my last question. What is the best piece of hardware that I can buy so that I can receive GPS on an none G3 iPad?
    Regards
    Chris Whitehead
    iPad Wizard
    49745
    370 times
    6,597
    Welcome. There have been plenty of detailed and useful threads covering this topic. They're available via the forum's search function. Bad Elf has been mentioned on the threads, in case that helps your search.
  1. Answer the Question Above with Another Question!
    By pEAcEmAKeR in forum Off-Topic
    Last Post: 09-17-2011, 06:46 AM
  2. Game: Answer question with a question
    By BrennB in forum Off-Topic
    Last Post: 05-25-2011, 02:14 PM
