im just wondering....how long does it take before we need to change the ipad's battery????
can anyone help me.....?????
This is a discussion on Battery life within the iPad 2 Forum forums, part of the Apple iPad Discussions category; im just wondering....how long does it take before we need to change the ipad's battery???? can anyone help me.....?????...
First, hello and welcome to the forum!
Second, you've obviously done no searching here - there are numerous threads/post already available on the iPad batteries - please use the search functions -
Finally, check Apple Support - there are plenty of KB articles available on using the iPad battery - check THIS ONE for a start - good luck and please post back if your question(s) is not answered by the above!
This has been my battery-charging system:
1) On a day to day or week to week basis, I charge it when the battery gets to about 30% or so. I let it fully charge back up before using it again.
2) Roughly once a month, I let the battery run completely down, to say 2-3% and then I fully charge it. This helps to calibrate the battery meter so the readings are more accurate.
Of course, you can charge it when it gets to 40% or even 60% and you wont hurt anything. The batteries are pretty robust in these things from my experience. Basically, charge whenever you see fit. Once in a while, let it run down almost totally. Thats about it.
32GB Wifi iPad 2 / OS 6.0
As far as lifespan of the batteries, I suspect we'll want the new version iPad that will be out by the time the battery dies(~ 3 years?)
I'm not impressed with my iPad 2 battery life at all. I've followed all the advice to minimize battery usage and still do not get the same life as my original iPad. I do have 3G in the iPad 2 but turned it off for a week and I still had to charge it every 2 days.
How many hours a day do you use it? I've had mine at work for the last 3 days. It started off at 100% and I've been on it lots (games, books), probably about 8 hours total and it's now at 30%. FWIW
