Argh ! Need help restoring firmware 4.3.3 pls ...
This is a discussion on Argh ! Need help restoring firmware 4.3.3 pls ... within the iPad 2 Forum forums, part of the Apple iPad Discussions category; ok my head is about to explode ... I am getting the dreaded 3194 error on restore but I think I have done everything right ...
Results 1 to 4 of 4
    77067
    Jul 2011
    29
    ok my head is about to explode ... I am getting the dreaded 3194 error on restore but I think I have done everything right !
    I am trying to restore to 4.3.3 which I have been running on pretty much since buying my iPad2 and I am jailbroken. I loaded a new app today and ever since then the pad has been stuck in reboot mode so I want to restore the iOS and start over, seems thats my only option at this point.
    So I run the TSS Server on the latest Tiny Umbrella, downloaded a copy of 4.3.3 and "shift-click" the restore button on iTunes and select the 4.3.3 iOS when in dfu mode and the restore starts then it stops a few seconds later with a "Error 3194". I have my 4.3.3 SHSH saved in TU so that should be cool. I even edited the host file just in case and that didnt help.
    I am totally baffled ???
    Thoughts ?
    iPad2 64gig 3G wifi - jailbroken 4.3.3, Zagg Folio (in Transit)
    iPhone 4 - jailbroken 4.3.3
    Invisible Shield everywhere, on everything !
    13576
    751 times
    Aug 2010
    Western NY state (USA)
    9,313
    Take a look at this thread here: Official iPad2 Jailbreak Thread
    Read the whole thing, but especially the paragraph titled "My iPad isn't new and I was previously jailbroken. Am I out of luck too?"
    So, if you have a GSM iPad (the AT&T one), you should be able to create a custom firmware and then jail break. It's a bit more involved than just getting the regular 4.3.3 IPSW from here (or Apple).
    Try the steps in the link I've attached - see if that does ya. Good luck and let us know how you get on.
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    You might also like to look at this tutorial to help you build the custom firmware you will need to restore - TUTORIAL - Use TinyCFW to restore 4.3.3 on iPad2 3G with saved SHSH Blobs
    Hope that helps.
    13576
    751 times
    Aug 2010
    9,313
    I KNEW you had a sticky/tutorial out there! Just couldn't find the durn thing!
    Added to my Evernotes "Stickies" folder...
    Thanks, f4780y.
  1. Argh! Asphalt 6 : Adrenaline HD help!
    By Hal05154 in forum iPad Games
    Last Post: 07-11-2011, 09:26 PM
  2. Risk HD... ARGH! help?
    Last Post: 12-26-2010, 01:42 PM
  3. Restoring to SAME 3.2.1 firmware
    By ztariqz in forum iPad Hacking
    Last Post: 09-01-2010, 02:45 AM
  4. ARGH! My iPad is broken...isn't it?
    By rickt in forum iPad Help
    Last Post: 06-15-2010, 01:36 AM
  5. ARGH! My iPad is ruined (isn't it?)
    By rickt in forum Off-Topic
    Last Post: 06-10-2010, 02:23 PM
4.3.3 to 5.1.1 custom firmware ipad 2
apple firmware 4.3.3
gets to restore ipad firmware and stops
how to restore my ipad to 4.3.3
how to restore to 4.3.3 2012
i need firmware 4.3.3
ipad custom firmware 4.3.3
ipad restore firmware
restore ipad from custom firmware
restore ipad to 4.3.3
restore ipad2 6.0 to 4.3.3
