Usually you press until wiggly icons, or just swipe the file or just re-sync
This is a discussion on first doubts within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Usually you press until wiggly icons, or just swipe the file or just re-sync...
Why not simply use Air PlayIt HD which not only let's you stream any and all music and movies from your home PC but also let's you convert said media and transfer it to your iPad without ever opening the evil iTunesOriginally Posted by hilfer
Never looked back since installing.
While not giving full access to my network I use Buzz player to play films off my PC and Popcornhour over wifi. Other than the high bitrate stuff it works well.
