IPad 2, no issues for six months. Now safari is constantly freezing when searching in google.
Any ideas for fixing. Ta
Try going to Settings > Safari and Clear Cookies and Data.
Also, here are the usual fixes for iPad problems, if you haven't tried them.
Hi and welcome to the Forum!
iOS5 Tips and Tricks
iPad 2 64gb 3G
I cannot go forward as my Safari page stopped in a site and can't let me go, any advice?
Thank you.
Thanks a lot, it worked cleanning cookies and historyOriginally Posted by twerppoet
