Need help connecting iPad 2 to home WI-FI
This is a discussion on Need help connecting iPad 2 to home WI-FI within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Using a D-Link DIR-615 modem, my notebook, android phone all are connected with no problems. When trying to connect the iPad, I get the message ...
Results 1 to 5 of 5
    143825
    Dec 2011
    California
    Using a D-Link DIR-615 modem, my notebook, android phone all are connected with no problems. When trying to connect the iPad, I get the message "Unable to join the network." Have worked on this several hours trying to research any problem on the D-Link site or Apple and am at a loss. I am no computer expert by any stretch of the imagination. The iPad does connect to the internet using my Android as a hot spot. Any suggestions??
    142191
    Dec 2011
    Massachusetts
    Under settings ----> Wi-Fi ----> Choose a network -----> Select your network.
    You can also go to the Apple Support site and look for Wi-Fi Assistant, which has a walk thru.
    70532
    8 times
    Jun 2011
    Springfield OH
    193
    I have found nothing unique about iPads joining networks. It sounds as if you are familiar with the general process with iPad settings and joining of netwoks, correct? Are you able to connect your ipad to other networks beyond your phone, such as at a coffee house, or airport?
    Like you, I am no expert with networks. Having said this, have you or anyone else performed a lot of configuring with your DLink router? Is it possible that someone has limited numbers of connections allowed on your router, or set up reserved port numbers, or disabled some of the automatic connection settings, or firewall settings? If your router is relatively stock, without someone having gone in and manually configured some things, I cannot imagine why your DLink router would not connect. My router is also DLink, (-825, I think) and my iPad connects without any problem.
    41947
    Bridgman, MI
    53
    Have you tried restarting your router? This will sometimes help with dlink roters.
    Regards
    Jim
    88980
    2 times
    Aug 2011
    54
    I know this is basic, but make sure the correct password was entered when the iPad was set up to access Wi-Fi. Also that Wi-Fi and Ask to Join Networks are ON in the settings. If you see the network under Choose a Network and it shows good signal strength, it should connect. If it shows a padlock, it needs a password. If everything looks OK, try turning the iPad off and back on to reestablish Wi-Fi.
  1. Replies: 3
    Last Post: 10-06-2011, 03:26 PM
  2. Connecting a second ipad to home computer
    By Boblins in forum iPad General Discussions
    Last Post: 09-29-2011, 12:38 PM
  3. Problems connecting to Home WIFI after Tethering to Android Phone
    By smfink3 in forum iPad General Discussions
    Last Post: 07-10-2011, 01:40 AM
  4. Connecting Splashtop Remote outside home pc
    By kc2tanker in forum iPad General Discussions
    Last Post: 10-09-2010, 08:51 PM
  5. Connecting Ipad to car
    By Marcelekusa in forum iPad Help
    Last Post: 07-11-2010, 08:07 PM
connect ipad to dlink router
d'link 514 and ipad 2 slow
d-link dir-615 and ipad
d-link dir-615 ipad 2
d-link dir-615 ipad problems
dlink 615 ipad 2
dlink ipad problems
how to connect ipad to dlink router
ipad 2 to d link
ipad cannot connect to dlink
ipad dlink problems
problems connecting ipad ii to home router
