Ipad 64gb wifi only......internet possible with mobile phone???
This is a discussion on Ipad 64gb wifi only......internet possible with mobile phone??? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi all, I've been told that even though I havent got a 3g Ipad2, just the 64gb wifi one, thats its possible to connect my ...
Results 1 to 10 of 13
    143424
    Dec 2011
    Norhtern Ireland
    Hi all,
    I've been told that even though I havent got a 3g Ipad2, just the 64gb wifi one, thats its possible to connect my mobile phone internet connection to the ipad2 to allow me to browse internet when i've got no wifi connection available.
    Question is .....Is this true, and if so HOW??
    Thanks for interest/help.
    56495
    May 2011
    India
    379
    You have to tether it..find some tethering app for ur mobile then connect it via wifi
    Sent from my White iPad 2 in India
    143424
    Dec 2011
    Norhtern Ireland
    Whats tether it mean?
    142520
    Dec 2011
    Chigwelll,Essex
    53
    Quote Originally Posted by iRuthlessPad View Post
    Is it easy to do and tethering app do you mean in itunes store yeah?
    -- Owner of ---
    iPhone 4 white 16GB
    iPad 2 white 32GB
    23518
    Dec 2010
    USA
    It can be done if you have a Data Plan on your phone. How to go about doing it, depends on YOUR specific phone.
    In our family we use Android devices on Verizon. I rooted everyone and now use a wifi tethering app. You can also use Hotspot from your service provider.
    52417
    18 times
    May 2011
    Dorset, United Kingdom
    287
    Providing you have a data plan for Internet on your phone you'll be fine. If you're using an android phone the chances are you'll be able to go into settings and then find your network/wireless settings and then you should have the option to create a tether which turns your phone into a wifi hotspot. The steps to do the tethering will more than likely be explained when you set it up for the first time. If you have a phone running iOS there may be an app for tethering although I'm not sure and if not you can probably do it through a jailbreak. Most smart phones nowadays should be able to tether, it's just finding the way to do it.
    Proud owner of a 32GB wifi iPad2 iOS5.
    iPad Addict
    121
    86 times
    Jan 2010
    Seattle, Washington USA
    1,293
    Quote Originally Posted by derrydave View Post
    Tethering means to turn your phone into a wifi hotspot. This effectively makes your phone perform the same function that a 3G radio in a 3G iPad performs. Some phones provide this functionality; others don't. Most of the smartphones released in the last year have the capability. The simplest way to accomplish tethering is to call your phone service provider and ask them to add tethering to your existing phone data plan. Typically this costs about $20 per month. Your carrier will then tell you how to set up tethering on your phone. (It's typically done by turning on the feature in the settings menu of your phone.) Once done, your iPad will recognize your phone as a wifi source. Connect to it just as you would connect your iPad to any wifi network and the phone will then connect to the internet just as it does when you're using the phone to surf the web.
    If you don't want to pay the $20 per month tethering charge, there are ways to activate tethering on your phone without informing your carrier. This typically involves "rooting" (on an Android phone) or "jailbreaking" on an iPhone. If you go this route, be aware that you are almost certainly violating your contract with your phone carrier. And while they cannot (or will not) determine that you are tethering another device to your phone, they will keep an eye out for spikes in your usage of 3G on the phone and may conclude your are tethering another device to use the phone's data plan. If that occurs, they can decide to charge you for doing so or may cancel your contract (though the latter is unlikely.)
    iPad Ninja
    3736
    13 times
    May 2010
    Minnesota
    1,515
    Quote Originally Posted by jsh1120 View Post
    Quick correction... You are not voiding your contract for the line. But essentially the warranty on a phone. However, there are ways to undo the changes to "unvoid" the warranty
    Sent from my DROID2 GLOBAL using Tapatalk
    Life begins, and spirits rise,
    and they become memories that vaporize,
    and the vapor becomes the dreams we devise,
    and while we are dreaming...
    Time flies...
    148263
    Jan 2012
    49
    Another option is you can set up a Mobil hotspot giving wify access to several devices without tethering a phone (which as best I can tell will mean changing your cell phone data plan) or using a computer. Virgin Mobil has cheapest option I've found because rather than signing a two year contract you buy by the month as service is needed and used. On my set you do not use this service you do not pay!
    149178
    Jan 2012
    Hi all,
    I have a motorola droid and I just Bluetooth the two together and now I'm on the Internet. Hope this helps
  1. App to use Internet from mobile phone
    By rgbt in forum iPad General Discussions
    Last Post: 10-11-2011, 07:40 AM
  2. Replies: 13
    Last Post: 09-08-2011, 02:07 PM
  3. How to connect to wifi generated by mobile phone?
    By mobi1 in forum iPad General Discussions
    Last Post: 04-06-2011, 10:12 AM
  4. Using Mobile Phone to Connect to the Internet
    By RAC in forum iPad General Discussions
    Last Post: 11-15-2010, 06:31 PM
  5. Replies: 3
    Last Post: 08-26-2010, 04:00 AM
can you use ipad through cell phone wifi
connect ipad to mobile phone wifi
connect ipad to wifi through cell phone
how to get internet from phone to ipad
how to get mobile internet on ipad wifi
how to use internet from phone to ipad
internet for wifi ipad in india
ipad 2 64gb how to use internet providers
ipad thats wifi only
using mobile internet on wifi ipad
wifi from cell phone to ipad
