Verizon 3G/4G Wifi Card
This is a discussion on Verizon 3G/4G Wifi Card within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I had downloaded the Polycom App for Video Conference connections and it works pretty well on 3G and home WiFi networks. Work is interested in ...
Results 1 to 2 of 2
    113246
    Oct 2011
    Massachusetts
    47
    I had downloaded the Polycom App for Video Conference connections and it works pretty well on 3G and home WiFi networks. Work is interested in using the IPad for video calls via WiFi and over the Verizon portable WiFi card that just needs a power source. When I register with the Verizon WiFi card I can make a video connection over 4G but am unable to receive audio/video from the other endpoint. Does anyone elkse use the IPad for business video calling or have used the Verizon WiFi card for video calling? Thanks.
    IPAD 2 Black 16 G WiFi + 3G
    113246
    Oct 2011
    Massachusetts
    47
    Found out that some port programming and configuration needed to tyake place on the WiFi (MiFi) Card for video to work.
  1. 4G/LTE Verizon Performance for a Wifi Only iPad 2
    By jsh1120 in forum iPad Carriers
    Last Post: 10-12-2011, 08:11 PM
  2. Verizon iPad 2 will run Netflix on 3g but not wifi
    By grega52 in forum iPad General Discussions
    Last Post: 05-26-2011, 03:54 PM
  3. Cradlepoint CTR350, Verizon air card & iPad
    By jerliz in forum iPad General Discussions
    Last Post: 01-02-2011, 11:44 AM
  4. iPad WiFi/3G vs. iPad WiFi + Verizon MiFi/Sprint Overdrive etc?
    By MachThree in forum iPad General Discussions
    Last Post: 12-18-2010, 05:02 PM
  5. Setting up Verizon Blackberry Tour Wifi Hotspot for Ipad Wifi
    By xlr8nflorida in forum iPad General Discussions
    Last Post: 06-14-2010, 11:09 PM
3g card connection on ipad wifi
air card for ipad 2 verizon
aircard for ipad 2
ipad 4 g or verizon air card
ipad aircard verizon
ipad connector kit to verizon 4g air card
ipad verizon air card
verizon air card for ipad
verizon air card ipad
verizon mifi 4g for videoconference
verizon wifi card
verizon wifi card for ipad
