Ipad -Important note deleted accidentally.. need urgent help to recover
This is a discussion on Ipad -Important note deleted accidentally.. need urgent help to recover within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi, i created an important note on my new ipad.. i accidentally selected all data on that note and hit the "8" key.. all the ...
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Moray
Thread: Ipad -Important note deleted accidentally.. need urgent help to recover
    141668
    Dec 2011
    UAE
    Hi, i created an important note on my new ipad.. i accidentally selected all data on that note and hit the "8" key.. all the data was replaced by "8".. as i didnt know how to undo, i opened a new note and the old note vanished..PLEASE.. advise on how i can recover that note!! many Thanks in advance!!!
    iPad Ninja
    62473
    69 times
    Jun 2011
    1,631
    Pretty sure UNDO was your only option...
    1522 times
    Walla Walla, WA
    15,430
    Yep. It is gone by now. Sorry.
    13576
    1445 times
    Aug 2010
    Western NY state (USA)
    11,052
    To chime in with the others, yes, UNDO was your only option.
    For the future: To undo, press the .?123 key on the left side of the keyboard. An undo button will show about in the same place. Pressing that will undo any actions. Do note that it will undo all the way back, in steps. So, if you delete something in one step, it'll undelete it. Then, if you press undo, the step you did before the delete will be undone.
    For example, I typed "test test test." Then, I highlighted the last two "tests" and hit the delete key. Then, I pressed the undo key and the two words came back. Then, I pressed undo again and all the words disappeared (which was the last action I performed before the delete...typing the three words).
    Hope that made sense. Oh, and do remember, there is no REdo key. It's undo or nothing. And, if you leave the note before applying the undo, it won't work.
    Sorry this is too late for your situation - but maybe this info will help in the future.
    229165
    Jul 2012
    Surrey, UK
    Hi - first of all, since all things are possible to those that believe, IF your note was ever saved to the ipad (meaning you didn't lose the note before it was ever titled & saved by the notes app) you could potentially have a data recovery specialist locate & recover the data. Depends on how much you value that content...
    Secondly, perhaps it was not possible in older versions of iOS, but in the version i'm running—iOS 5.1.1, non-jailbroken—you can undo an action as described above, but you can also redo. Simply press the .?123 key, then the #+= key and, voila!, undo has turned to redo which can also be applied in stages. Hope that helps!
    157699
    Jan 2012
    France
    36
    Quote Originally Posted by Mickey330
    This reminds me of a true story from The early days of graphical interfaces. There was a computer that could be in two modes, EDIT or RUN. Unfortunately there was no indication of which mode you were in. If you were in RUN and you typed EDIT , you entered EDIT mode. But if you were already in EDIT mode, then typing EDIT was interpreted as Everything - Delete - Insert - T. The result was to wipe your entire programme and print the letter "T" in the top left hand corner of the screen.
    npm
    Mickey330 likes this.
    13576
    1445 times
    Aug 2010
    11,052
    Quote Originally Posted by Moray View Post
    npm
    Oh, but that's too funny!
    Not necessarily to the person running it - but to me, yes!
    Good thing that programming (and interfaces) have improved, yes?
    Thanks for this anecdote.
  1. Replies: 5
    Last Post: 08-29-2011, 11:23 PM
  2. Woops, accidentally deleted utilites on ipad2
    By camnsteph in forum iPad Help
    Last Post: 07-17-2011, 10:24 PM
accidentally deleted my notes on my ipad
how to restore how to undo typing on ipad
how to undo delete ipad
how to undo delete on ipad notes
how to undo something on ipad notes
ipad 2 how to undo delete in notes
is there any way to undo something deleted on ipad notes
pressed how to undo on ipad notes
