Little Wheel in Center Won't Go Away
This is a discussion on Little Wheel in Center Won't Go Away within the iPad 2 Forum forums, part of the Apple iPad Discussions category; If I try to shut down normally using the on/off in the corner, a little wheel starts spinning in the middle of the screen and ...
Results 1 to 4 of 4
Like Tree2Likes
  • 2 Post By Mickey330
Thread: Little Wheel in Center Won't Go Away
    71024
    Jun 2011
    27
    If I try to shut down normally using the on/off in the corner, a little wheel starts spinning in the middle of the screen and stays there and stays there and stays there. Finally after about 2 hours I did a hard boot and shut it down. But when I go to turn it off again the same thing happens??? Every time I try to turn it off the screen goes black and the little white wheel in the middle spins and just stays there...Any suggestions???
    Thank you for any insight.
    13576
    743 times
    Aug 2010
    Western NY state (USA)
    9,278
    When you do "a hard boot and shut it down," are you holding the sleep and Home buttons until you see the Apple logo appear? As in, do you do the full sequence for a reset (Apple's name for a reboot): Hold both the power and home buttons until the screen goes dark and the Apple logo then appears (the slide to unlock screen may or may not appear). Once the logo appears, release the buttons. After a time, your homescreen will appear. Please note that it may take some time for the Apple logo to appear or for your homescreen to appear (or both). This is normal. Eventually, the homescreen will appear.
    Sometimes, the iPad does get "hung up" when you do the "slide to power off" action. The reset usually helps. If that's not the case, or this doesn't help, holler back and we'll see what else we can try.
    71024
    Jun 2011
    27
    The first time I did a "reset" like you described, it did not help and when I went to put it to sleep --- the little wheel came up and still stayed there.....BUT the second time I put it through the reset schedule, it seems to have fixed the problem. Now it will go to sleep normally if I hit the sleep button briefly. Before, when the wheel was spinning ....nothing worked....I think you have helped me by having me do it again ...actually I did it a couple of times
    .If you have the time --- What's this "hung up" thing you refer to??? Is there some type of software glitch that the techs can't fix? I have not seen it do that before. Is it very common? It was very frustrating.
    Thank you very much for taking the time to reply....I appreciate your help. I think I am OK now. This forum is great. I looked for info on the wheel turning for time eternal and could not find anything. You helped me out nicely...THANKS. MERRY CHRISTMAS.
    13576
    743 times
    Aug 2010
    9,278
    Quote Originally Posted by Panama View Post
    I would like to give you a detailed, technical explanation as to what's going on. I would also like to tell you that it's not very common. But I can't. Mainly because, underneath all the shiny gloss and pretty icons, the iPad is merely (!) a computer. And, at times, computers act up and need a swift kick in the software.
    Here at iPad forums, we have found that the first thing to always try when your iPad is not behaving normally, or as you'd expect, is to do either the restart or the reset process. The reset is as I described above, the restart is the "slide to turn off," wait a bit and then press/hold the sleep button until it turns back on. A lot of times, it takes both these processes to get the iPad back to behaving as it should.
    Again, I wish I could provide you better reassurance. However, since the iPad is a computer, it's best to just save the restart and reset instructions for the next time...
    And a very Merry Christmas to you, also!
    SweetPoison and twerppoet like this.
  1. Steering wheel mount for iPad DIY Plans!!! Really!!
    By Dannyboy85 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 02-20-2012, 09:29 AM
  2. Use Your iPhone As a Steering Wheel In REAL RACING 2 For Mac
    Last Post: 12-24-2011, 11:58 PM
  3. Help!!! Ipad 2 blank screen with spinning wheel
    By toocoolforipad2 in forum iPad Help
    Last Post: 08-09-2011, 06:20 PM
  4. Spinning Wheel of Death
    By brooker1992 in forum iPad Hacking
    Last Post: 09-24-2010, 02:55 AM
  5. Crazy iPad Wheel Mount
    By dim3m in forum iPad General Discussions
    Last Post: 06-13-2010, 07:14 PM
apple and little wheel won't go off of my ipad
ipad 2 problem screen black and spinning circle doesnt go away
ipad spinning wheel after reset
ipad twitter saving url
ipad won't turn off spinning wheel
ipad wont turn on circles
iphone black screen with spinning circle won't go away
iphone wheel in center
iphone wont spin dial at startup
powered iphone 4 down and and spinning circle wont go away
saving url on twitter won't go away
saving url on twitter wont go away
