Results 1 to 10 of 10
    124723
    Nov 2011
    United Kingdom
    8
    Using my iPad with a projector
    I regularly conduct training using PowerPoint slides at other peoples premises and would like to use my iPad for this. I've bought a connector for iPad to projector connectivity but now am not sure what to do next. So how do I get the PowerPoints to my iPad, what app can I use to display them? sorry if this is basic stuff but just learning to use my iPad!
    82526
    282 times
    Jul 2011
    South Australia
    899
    Quote Originally Posted by HollyUK
    There are a couple of ways. You can bring them in from your PC and save them but it helps to have a POwerpoint program. I use keynote and download all my power points to keynote and then use my iPhone 4 which has keynote remote to remotely activate the slides. It's really very good and I am not sure what other PowerPoint programs there are. I like keynote it's simple and easy to use. I have also created training presentations I key note.
    MJ
    A mistake is simply another way of doing things.
    126602
    Nov 2011
    Toronto
    28
    Keynote is definitely one option, and probably the best one. You can also use other software such as QuickOffice. There's also the 'free' option, but it isn't very good if you regularly do presentations.
    The free way would be to email the ppt file to yourself as an attachment. You can then open the attachment from within the email - there's a basic built-in ppt viewer. However, once you delete the email, the file is obviously no longer on your iPad.
    If you decide to go with Keynote/QuickOffice, you could either email them to yourself, but better still, you can transfer them to your iPad using iTunes. You do this by doing into iTunes while you've connected your iPad to your computer, click on your iPad on the left side, go to the 'Apps' section, scroll down until you see Keynote or QuickOffice, and then 'adding' your ppt files. It will synch instantly and now your ppt files will be on your iPad. This way, the files are on your iPad until you delete them.
    68030
    Jun 2011
    I have used iTunes to transfer .ppt files into Keynote for iPad. Most slides will transfer well except for few fonts which are substituted automatically. Equations transfer as images and may look distorted. I use an equation app to recreate those equations that need to be replaced. I use a VGA adaptor to project the slides to a screen. If you touch the slide and hold, a red dot will appear like a laser pointer. I have used this setup to teach two full courses without any problems. I switch between Keynote and Notes Plus App which I use as a whiteboard to draw using a stylus. The students appreciated the way this was presented in class.
    142889
    Dec 2011
    Have you found a way to use the projector, the iPad and have the iPad hooked to a charging source? My presentations are seven hours long.
    88167
    Aug 2011
    38
    Apps like Docstogo allow you to play/create powerpoints on your device, you could play your powerpoint on the iPad whilst it's connected to projector to show it?
    140197
    2 times
    Dec 2011
    Maple Grove, Minnesota
    58
    Quote Originally Posted by missybradley
    This is a problem. I use presenting alot with my iPad, but it burns the battery and I need to charge while presenting. I have not found a solution yet... :/
    Sent from my Verizon 3G iPad 2 64GB using iPF
    135848
    Dec 2011
    Liverpool, UK
    110
    The Apple Digital AV adapter has HDMI out to connect to the projector, and allows simultaneous charging.
    140197
    2 times
    Dec 2011
    58
    Quote Originally Posted by iDuffer
    You are correct. I totally forgot about the HDMI choice. I just ordered it from Amazon for $39. That should do the trick.
    Thank you Mr. Duffer!
    48409
    Texas
    5
    Quote Originally Posted by Ranjan
    I have found Dropbox to be a good solution to transfer my .ppt files to the iPad. Nice way to keep the presentations synchronized between my laptops and IPads since I use several different machines for different clients.
  1. Replies: 1
    Last Post: 12-15-2011, 08:09 PM
  2. Another projector review: The AAXA P4 Pico Projector
    By fourier in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 11-09-2011, 03:34 PM
  3. Ipad with projector!
    Last Post: 08-05-2011, 01:08 PM
  4. iPad Projector
    By Grumbles in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 02-14-2011, 10:53 AM
  5. ipad to projector or tv
    By cgvanand in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 10-14-2010, 03:53 AM
connect ipad to projector powerpoint
how to connect ipad to powerpoint projector
how to present powerpoint on projector from ipad
how to show powerpoint on projector ipad
ipad powerpoint projector
ipad ppt projector
powerpoint from ipad to projector
powerpoint presentation on ipad projector
powerpoint projector for ipad
powerpoint projector ipad
using ipad 3 while charging presentations
