duplicating entries in calender
This is a discussion on duplicating entries in calender within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Calender is doing my head in. It's duplicating, triplicating and even more all my events, and I can't even delete some of the replications. Is ...
Results 1 to 6 of 6
    126119
    2 times
    Nov 2011
    89
    Calender is doing my head in. It's duplicating, triplicating and even more all my events, and I can't even delete some of the replications. Is anyone else having the same problem, or does anyone know how to stop it?
    126119
    2 times
    Nov 2011
    89
    Sorry -that should say Calender is doing my head in!
    PS. Oooh- just found the edit button!
    46070
    53 times
    Egremont
    979
    It sounds like you are syncing via two or three different methods, when you should just be syncing via one. Do you sync your calendar via itunes, icloud, exchange, imap? More than one of them?
    126119
    2 times
    Nov 2011
    89
    As far as I know it just syncs when I sync through iTunes - ie. connect to my MacBook, and iTunes syncs automatically. I'm giving up on iCloud, as it's just a nightmare.
    122185
    Nov 2011
    28
    I turned off iCloud in settings, synced, then back on, helped somewhat, still checking.
    1523 times
    Walla Walla, WA
    15,432
    Quote Originally Posted by Waterbabies View Post
    iTunes is the worst method, in my opinion, but if you want to use it make sure you've turned off your Calendar (and whatever else) syncing both in your System Preferences > iCloud on the MacBook and in Settings > iCloud on the iPad.
    That won't get rid of the current duplicates (you will have to do that manually) but it should prevent future ones. Then all you will have to deal with are the conflict resolution dialogs and the are-you-sure because it changes xx% warning when syncing through iTunes.
  1. Calendar does not allow entries since update
    By bjlocklear in forum iPad Help
    Last Post: 11-25-2011, 06:12 PM
  2. Double entries in Contacts
    By bbulow in forum iPad Help
    Last Post: 11-20-2011, 07:32 AM
  3. iCloud Calender and gmail calender
    By willywonka in forum iPad Help
    Last Post: 10-25-2011, 05:10 AM
  4. Apps duplicating
    By Badb0yRick in forum iPad Help
    Last Post: 08-20-2011, 05:27 AM
  5. Duplicating itunes account on second pc
    By 55julie55 in forum iPad Help
    Last Post: 04-03-2011, 07:11 AM
duplicate calendar entries on ipad
duplicate entries in ipad calendar
duplicate entries ipad calendar
duplicate events on ipad calendar
ipad calendar duplicate entries
ipad calendar duplicate events
ipad calendar shows duplicate entries
ipad duplicate calendar events
